Question about Microsoft Xbox 360 Console
Xbox 360 E71error Hi, a few days back i went on xbox live, and it asked me to update. It got halfway through the update, and did not have any space left. Today, i purchased a 20GB hard drive, now it will load up, if i leave it on for about 1minute then restart it would load up the E71 error message. Rest it for 10mins, all power off, will work again. but cannot connect to xbox live otherwise it would get the error again. Any ideas? Regards.
  • 142 Answers
Call microsoft, your xbox is broken. 18004myxbox
Posted on Jun 21, 2009
My xbox 360 keeps teling me i need an update for xbox live i do the update it lasts for a bit and than says files missing need a xbox live update
It is possible that there is no room on your console to download the update. Make sure there is space on your hard drive/memory card to download the update then try again. I hope this helps and have a nice day!
May 03, 2011 | Video Game Consoles & Games
Hi i have a xbox 360 and brought a xbox game but it won't play why ?
Only a very few selected xbox games will work on a xbox 360. You need to buy xbox 360 games to work with the xbox 360. Here is a list of xbox games that can work on xbox 360
http://en.wikipedia.org/wiki/List_of_Xbox_games_compatible_with_Xbox_360
If this answered your question, please rate my solution! thanks
Mar 01, 2011 | Microsoft Xbox 360 Console
E 71 error code
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
Will not update Xbox live
Mine did this same thing for the November 1, 2010 Kinect update. I hit yes, update now and it said it could not connect and brought me back to the prompting screen. I then shut off my xbox and turned it back on and the update went right through.
Nov 01, 2010 | Microsoft Xbox 360 Console
When i turn the xbox 360 on it says that i have to do an update for xbox live but the update wont work
My xbox did the same thing, this is how I fixed mine. After I got the message saying the update was unsuccessful, I went to settings, and network settings. I tested the network connection and the test came back with no problems, but before my xbox signed my profile back in (your profile is automatically signed out when you do a network test) it asked me again if I wanted to update and I said yes, this time it worked without a hitch.
E 71 error on xbox 360
Sorry timehrhart you've just copied a huge section from Xbox Scene forums without mentioning the Reset codes.
Back to the question - E71 is due to a dashboard update, most new Xbox consoles get this error due to missing a patch that was available to download when the new Xbox dashboard came about.
To fix this you have to clear all game updates and clear the console cache and update your console via Xbox Live. To do this on the old dashboard layout go to the 'System' blade and then Console / on the new dashboard go to 'My Xbox' tab and then go to the far right and choose the 'System Settings' and then Console and then go to the 'Memory' section. Press Y and enter this code - X,X, Left Bumper, Right Bumper, X,X.
You will get a message asking if you want to clear your cache, press Yes and just wait for it to do it's thing and it should come back to the dashboard. Now you have to update your console via Xbox Live and hopefully it should fix the problem.
If this should fail then you have to send your Xbox back to Microsoft for it to be fixed. Microsoft have extended the warranty of any Xbox to 3 years if it has the E71 or Red Ring of Death error, so hopefully you should be covered.
Mar 13, 2009 | Microsoft Xbox 360 Console
Cn't connect to Xbox Live
do you have it hooked up with an ethernet cord
Jan 11, 2009 | Microsoft Xbox 360 Console
Recovring gamertag problem
Corrupt File (microsoft cant let you recover gamertag due to mods hacks and such) that is possibly what has happened. You downloaded a corrupt file and now microsoft has found something wrong. You can no only make a new gamertag and ask for free xbox live for compensation. (you might get it)
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 update problems
cut the power from it then try to resart ur update over
Aug 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
234 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
