Question about Danby DWM99W Top Load Washer
FILLS WITH WATER AND DOES NOT AGAITE
FILLS WITH WATER AND DOES NOT AGIATE
    President:
  • 1,564 Answers
100% sure you need a new belt, or at least an adjustment to it.
Posted on Jun 20, 2009
Kenmore washer 80 series will not agiate
What is the model number of your unit?
Nov 25, 2012 | Washing Machines
Machine fills and drain but will not agiate or spin. Roper model# VBXR1090DBWW
that is a broken motor couling that couples the motor to the transmission.This video will show you how to replace that coupler. The part number is 285753A it could be purchased from your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
assuredparts.com
appliancepartspros.com
repairclinic.com
Aug 11, 2011 | Washing Machines
GEfront loader no agiate or spin just pump motor
Hi there, you may have a locked up gear case or drive shaft and clutch issues as well. i would check these points. also, check the motor connection for lose or separated connection. Here's another tip. there may be a pin coupler on the control panel that is not connected or lose. i would run a break point test on the control panel board as a last result.
please rate and god bless.
Mar 17, 2009 | Washing Machines
I have a kenmore portable washer and I can wash clothes in it and the water fills up and starts to overflow and the washer does not spin or agiate
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Danby DWM99W Top Load Washer Logo
81 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Gerry Harvey
Gerry Harvey
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
