Question about AudioBahn A4125HCQ Car Audio Amplifier
Proction stays on
It was working i turned off the car and when i turned it back on the proction was on i rewired it and the same thing stuck in protion
  • 26 Answers
CHECK ALL UR WIRE AND FUSES .. MIGHT BLOW ... OR UR REMOTE WIRE FUSE ... SEE U ..
Posted on Jun 23, 2009
How to rewire a backup switch on a Manuel transmission for a 1989 jeep wrangler
use a fuse never un wires unfused, ever
it works just like a flash light.
battery > switch>>> lamp.
so if the lamp is stuck on the switch is shorted.
"...reverse, but the light stays on, all the time."
Feb 13, 2015 | Jeep Cars & Trucks
Proction light stays on
If it stays on even when the speaker are not connected to it then the amp is fried but f it goes off when the amp is hooked up with no speakers then check the Ohm load on the amp and wire the speakers to match that but don't go below the ohm load on the amp...this site will help.... http://www.crutchfield.com/S-ApB0sVuYqNs/learn/learningcenter/car/subwoofers_wiring.html
Aug 13, 2011 | Performance Teknique ICBM-774 Car Audio...
Just bought this car 1993 gand Marqu.And the fuel pump stays on all the time causing the battery to die. How can I fix this?
Hello, The first thing you should replace is the fuel pump Relay. This part should be in the Powerbox under the hood. When you turn on the Ignition, the Relay is suppose to activate and power the fuel pump. If the Relay is stuck on, then your fuel pump will continue to run.
I hope this is your problem, because if it is not, then the wiring is either shorted or someone has rewired the circuit incorrectly. The fuel pump pressure Regulator can control the pump running, but it should be dead when the Ignition is off.
I hope my Solution is very helpful.
Jun 19, 2011 | Mercury Grand Marquis Cars & Trucks
Heater blower continues to run when truck is turned off..
If that is the only thing that stays on, then it is possible someone rewired the heater directly to battery and bypassed the ignition switch.
Dec 13, 2010 | 1996 GMC Jimmy
Removed auto shifter and overdrive wires broke and its stays in 3rd gear all the time is there a way to make iit rewire it to stay in 4th ?
see where the wiers from overdrive go and fix there a switch. all it is a switch. or just connect the wiers together to turn the overdrive off
Jun 02, 2009 | 1993 Mitsubishi Diamante
How do you rewire a trailer
Are you putting on a 4 wire flat connector? Trailer Wiring
4 Flat Small
Brown = Tail Lights
Green = Right Turn Signal & Brake Light
White = Ground
Yellow = Left Turn Signal & Brake Light
Feb 01, 2009 | 1995 Ford Escort
Headlight wont turn offcole family racing
Only 2 things can cause this either the headlight switch or the headlight relay,chances are it's the switch,if you have a multimeter pull the relay out and probe the leads with the headlights in the off position you should only have power on 1 wire,with them on 2 wires are hot if this is the case then the relay is stuck,it's in the fuse box under the hood,another thing can cause this if the fog lights have been rewired to stay on even with highbeams on,power will feed back to the headlight circuit.
Jan 10, 2009 | 1997 Jeep Grand Cherokee
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
AudioBahn A4125HCQ Car Audio Amplifier Logo
48 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
