Question about LG WM-2277HW Front Load Washer
Mines does the same after washing and going into the dryer cycle
I get the error code FE and water fills doing the dryer cycle. Also water comes out of the back vent
  • Butchybutch Jun 20, 2009
    My model is the WM3988HWA and its only 3 months old. It works on wash but won't complete the dryer cycle
  • LG Master
  • 13,433 Answers
Fe - OVER FLOW ERROR • Water is overflowing. If FE is displayed, the drain pump will operate to drain the water automatically.
Here is the service manual for your washer
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
As the washer probably doesn't require water during the drying cycle, lower or close the water valve.
Posted on Jun 20, 2009
  • Ekse Jun 20, 2009
    The meaning of the FE error is still the same. since its such a new machine, you should call your dealer to get someone fix it for free, I believe its on warranty.
I have LG WM2487H*M and at begining of wash cycle when the water is filling, the FE code comes on and it keeps filling with water then drains the water when it reaches a level. What is wrong? I then shut...
Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically
LG WM2487HM series Service Manual Error Display
Oct 26, 2017 | LG WM2487HA Washer
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
FE errror code, can fill valve be replaced by owner?
FE Over Flow Error
• Water is overflowing (water level frequency is over 213).
(may be too much suds ...)
WM2277HW Service Manual
0r
Locate your service manual behind the kick panel of the machine.
FE means overflow condition.
Before replacing the fill valve sand or trash may have gotten into the tube going from tub to water level switch.
So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | LG WM3431 Front Load Washer / Dryer
Display code FE... what needs to be done
FE in an over fill error. (the pump should automatically come on to drain water) If the machine is not overfilling, check the thin hose that goes to the water level switch. If it is overfilling you will either need to replace the inlet water valve if it is filling with no power to the vavle, or the main control board if it is receiving power in the FE condtion.
Oct 08, 2009 | LG WM3988HWA Front Load Washer / Dryer
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
90 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
