Question about Blueair Refrigerators
Problem with blueair cooler model # EGR48
Intermittent starting problem, please help
What size is the fuse on the Blueair purifier.
Hi there.
15 amp. Also remember there is a reason why the fuse is not working. Goodluck ..
Sep 23, 2017 | Blueair Air Purifiers
Blueair 301 Air Purifier Owners Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Blueair model by clicking the link below.
You can purchase a wide variety of high quality Blueair replacement parts for your Blueair Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jan 21, 2013 | Blueair 301 Air Purifier
Can i transport this blueair basr2 on it's back?
Not a good idea because the oil will flow into evaporator and you may have forever trying to get compressor to restart. Hope this was helpful and should you have any questions I will be here to assist you., Thanks, Sea Breeze
Nov 16, 2011 | Blueair BASR2 Stainless Steel Refrigerator
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
Toll Free # 001-866-677-8500 FAX 001-310-808-0242 / 1-310-808-0262 E-mail 00Admin : / Sales Team :
sorry couldn't delete it. why not call blueair and ask them product info on that model and see what they say if there is any particular problems with that model. ask about warranty and recalls
hope this helps
Mar 26, 2010 | Blueair 23 cu. ft. / 651 liter Commercial...
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
Jun 05, 2009 | Blueair 501 Air Purifier
I had the same issue.  Press and hold the 'TIMER' button untill you hear a beep and it will reset.
Apr 02, 2009 | Blueair 250E Air Purifier
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Refrigerators Logo
63 people viewed this question
Top Blueair Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Blueair Refrigerator Expert? Answer questions, earn points and help others
