Question about HP LaserJet 5si Printer
How do I fix error 79 Service 65ff - HP LaserJet 5si Printer
2 Suggested Answers
  • 24 Answers
SOURCE: HP LaserJet 3200se 79 service error 694:SM.C
1st shut the printer off
2nd Disconnect it from the Computer
3rd turn it on
Does the error still occur?
If it starts properly print a configuration page.
If this is possible you have a Printer Driver issue.
Replace the Print Driver.
If it still has the error when the printer is NOT connected to the Computer then you have a firmware issue most likely.
Posted on Nov 06, 2008
HP 400 stuck initializing
79 is an firmware error. Try to update the firmware. You can find the file on HP website, on the Drivers and Support section. There must be also the procedure to execute the update.
May 29, 2014 | HP LaserJet Office Equipment & Supplies
79 service error
Would appear that either someone has put in some bad memory or the memory that came with it has gone bad:-
You could try taking the memory out to eliminate it.
79 Service error
Description
An incompatible DIMM is installed.
Recommended action
  1. Turn the product power off.
  2. Install a DIMM that the product supports.
  3. Turn the product on.
If the message persists, contact HP support.
Dec 28, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
HP LaserJet M425dn MFP 79 Service Error
How To Troubleshoot HP 79 Error?
This is a fairly found as a common HP printers error which is usually caused by malformed PostScript documents in the HP printer. According to the study by a HP error 79 technical support professional team experts, printer shows a "79 Service Error" on the LCD display. HP service error 79 is a considered as a quite generic issue which is found on the HP LaserJet printer while working. Most of us face this same issue unexpectedly. But there are ways to get over with it:
What you need to have?
- Internet access.
-Admin account for the computers
Steps to resolve this HP error code 79
    ?In the very first step, you are needed to switch on the LaserJet Pro 400 printer.
    ?Ensure that the printer is properly connected to the internet. Users should be able to have a strong
    ?Ethernet cable connection running from the device to their modem or may even require to switch or a router.
    ?Now in the M401dn control panel/display section, click on the "Network" icon first.
    ?As per as study by HP error 79 tech support is concerned by a HP error 79 tech support technicians, verification of the IP address on the printer machine is necessary. Well, if it shows 192.168., then it clearly signifies that you are well connected to your home network. Else, a small check is needed to receive a symbol like 169.....
    ?Now step back to the home display section and then click on the "Settings" icon.
    ?Choose an updated LaserJet printer and then perform a check for all the firmware updates to ensure about all the latest updates.
    ?Continue the process by choosing a proper update and then click on the download and install button
    Fix your HP issues anytime with our HP professionals
    We deliver the best-in-class HP customer support service solutions for HP users across the world equipped with top-notch HP printer support solutions by applying the latest technologies to match users' need. Our HP printer support Toll-free 1-800-213-8289 number is all-time accessible for users across the world at our toll-free calling contact details to fix various critical types of HP printer problems affecting the performance of your HP printer. Prices are extremely feasible in nature.
Sep 16, 2013 | HP LaserJet Pro 400 MFP M425dn
Designjet z2100,what is System Error 79:04
I researched and found several options to fix, hope it works for you.
There are two (2) ways to fix 79 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 79) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Click here follow the steps to fix error 79 and related errors.
To Fix (error 79) you need to follow the steps below:
Step 1:
Download (Error 79) Repair Tool
Step 2:
Click the "Scan" button
Step 3:
Click 'Fix All' and you're done!
Compatibility: Windows 7, Vista, XP
Download Size: 1.5MB
Requirements: 300 MHz Processor, 256 MB Ram, 22 MB HDD
79 Error Code is caused in one way or another by misconfigured system files in your windows operating system.
So, If you got 79 Error then We strongly recommend that you Download (Error 79) Repair Tool.
This article contains information that shows you how to fix your windows 79 error both (manually) and (automatically) , In addition, this article will help you troubleshoot some common error messages related to 79 error code that you may receive.
Nov 14, 2012 | HP Office Equipment & Supplies
HOW TO FIX ERROR 79 ON THE PALOMA GAS WATER HEATER MODEL PH-241CWH (1)
Use following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://www.palomastore.com/paloma_error_codes.html
Range of problems can vary from fan motor wiring, to remote control terminals (error 76), to bad remote, to bad circuit board.
1) Replace remote control
2) Read error 76 and 79 shown in link above
3) Contact local service technician
4) Contact Rheem
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 29, 2010 | Rheem Tankless Hot Water Heater...
Error code 79:04
From the service manual:
System Error: 79:04
Problem Description: Firmware Error.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer on again and check if the Error Code has disappeared.
If the Error Code reappears, check for a new Firmware release.
The firmware upgrade and tool can be found here.
Jun 16, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
3rd turn it on
Nov 06, 2008 | HP LaserJet 3200se Printer
HP LaserJet 5si Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
