Question about Apple iPod touch
Forgot my passcode
I forgot my passcode and now i cant even try a different code because it is disabled; how do i restore the whole ipod touch without the passcode
  • 342 Answers
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Posted on Jun 20, 2009
    Scholar:
  • 94 Answers
Try holding the "menu" button and the "Play/pause" button at the same time for about 10 seconds
or,
Try restoring iPod touch using the latest version of iTunes.
Connect iPod touch. When it appears in the Source list, click on Restore in the Summary tab.
Ipod touch is disabled
Take to apple shop or go to iTunes on pc
Jul 28, 2012 | Apple iPod touch Second Gen (8 GB,...
Ipod is disabled forgot 4diget code
If you really can't remember the passcode, the only thing you can do to make your iPod touch work again is by restoring it, which means all data in your iPod will be removed!
To see the step by step guide, click here.
For more iPod touch / iPhone tips, click here.
Feb 27, 2010 | Apple iPod touch
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Jul 29, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod disabled connect to itunes
Jul 28, 2009 | Apple iPod touch
Forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Jul 23, 2009 | Apple iPod touch Second Gen (8 GB,...
I cant get on to my itouch.
When you connect to the computer, click on "restore". It will then put your ipod back to the beginning settings, and you can set a new passcode.
Jun 01, 2009 | Apple iPod touch
Forgot my pass code to my apple ipod touch 8g
i entered in my pass code and went on a vacation with out my ipod and forgot my pass code. is their somesort of universal code to enter to unlock my ipod? pllzz help me!!!!!!!!!!
Apr 18, 2009 | Apple iPod touch
Unlock code from ipod
It depends on the severity and the settings you have given the iPod... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
Feb 12, 2009 | Apple iPod touch
Ipod is disabled
From what I gather in your post, it seems that your touch has had too many wrong attempts at the passcode, so now it won't even give you the number pad to try again.
It is now necessary to restore the touch on the computer that was used to originally sync it, so you can reset your passcode and resync the data.
If you use a different computer, you will be able to unlock and remove passcode, but you will lose your data.
The link below will explain what I said a little better, and at the end of the article there is another link on how to actually update and restore your touch.
Jan 01, 2009 | Apple iPod touch
How to reset password on itouch
how can i reset my ipod touch when its disabled
Oct 12, 2008 | Apple iPod touch
Apple iPod touch Logo
579 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
