Question about Apple iPod touch
Wifi problems (iPod G1)
Okay i have a rauter in my house n i got an ipod touch for christmas n the wifi worked perfectly for like 4 or 5 days then it froze,closed itself n when i tried connecting it again my connection wouldnt appear and so i couldnt use wifi i already resetted ipod network settings and rauter n still dosent work.i have a psp n a laptop i can connect both of them but not my ipod it wont log in anywhere PLZ HELP!!
    Problem Solver:
  • 8 Answers
I had experienced that problem with my PSP at the same case,just set your internet connection again and delete all of you history,cache and some data in you iPOD.HOPE I HAD HELP
Posted on Mar 03, 2010
I can't connect my ipod to the internet
If you're having trouble with your wifi connection,try to follow this steps.
* iPod Touch shows no WiFi address (Tap Settings > General > About and scroll down to WiFi Address.
* iPod touch appears to be connected to a WiFi network but cannot use Wi-Fi for checking email and surfing the Internet.
* iPod Touch WiFi icon is showing as grayed out.
* When you tap Settings > WiFi and then you see no network entries.
If you have wireless problems,here is another method to do.
First you need to back up your data by syncing your iPod touch to iTunes. It is very important you do this before proceeding with the fixes below.
1. On the iPod Touch go to Settings > General > Reset and then select Reset Network Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 2 below.
2. On the iPod Touch go to Settings > General > Reset and then select Erase All Content and Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 3 below.
3. If the above fixes don't work then the only thing left is to restore the iPod touch software using iTunes which will erase all data on the device. So before restoring make sure you back up your data by syncing with iTunes.
After the restore is complete, you can resync with iTunes to load the data back to your iPod Touch. Now see if your device shows a WiFi address (tap Settings > General > About and scroll down to WiFi Address). If none of the above settings and fixes work ,then you might want to consider getting your iPod touch repaired by Apple.
Jul 20, 2011 | Apple iPhone Smartphone
Tip
How to Fix Wi-Fi on Iphone/Ipod Problem?
This are the common problems of Iphone/Ipod Wireless Fidelity...
1.On the iPod Touch go to Settings > General > Reset and then select Reset Network Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down toWiFi Address. If there is a WiFi address listed then you issue is resolved. Else try method 2 below.
2. On the iPod Touch go to Settings > General > Reset and then select Erase All Content and Settings. Now see if the device displays the WiFi address under Settings > General > About and scrolling down to WiFi Address. Ifthere is a WiFi address listed then you issue is resolved. Else try method 3 below.
After the restore is complete, you can re-sync with iTunes to load the data back to your iPodTouch. Now see if your device shows a WiFi address (tap Settings >General > About and scroll down to WiFi Address). If none of the above settings and fixes work ,then you might want to consider getting your iPod touch repaired by Apple.
Hope you see it useful...
on Jul 22, 2011 | Cell Phones
Ipod touch wifi problem
Am not sure.. but try this.. it mite help ya out..
Under devices u get d name of d ipod.. right click on it n u needa check sumthin which will give u d error msg if any..
Once ya get d error msg den go to apple website n give dat error msg in d search field.. u'l find out d trouble shooting assistence..
May 01, 2010 | Apple iPod touch
Wont connect to internet
To connect to the internet using wifi on the iPod touch, just follow the following steps:
Firstly, you should be in a wifi zone(an area where you can access wifi) or if you want to use it at your house with your residential internet connection, just get yourself a wifi router(shouldn’t cost more than $50-60) and configure it with your residential internet Once you are in a wifi zone, on your iPod touch, go to:
Settings > Wifi > Turn your wifi ON > Select a wifi network > Key in the WEP(only if asked for) > Connect
Once you’re done with this, you should get the IP settings and be able to surf the internet with no problem.
Note: At times when you’re too far away from the wireless router or a big thick brick wall is separating you and the wifi router, your iPod might show the network as available and you would also be able to connect to it, but surfing the internet using it would become a problem. If this happens to you, don’t worry, just move closer to the wifi router and it shouldn’t pose any other problems. Happy Surfing!
dont forget to rate me.....
Apr 05, 2010 | Apple iPod touch
Cant unlock Wi-Fi connection so that i can go on the internet on my ipod
hello, i just solved my ipod wifi problem. first i turned off the computer and ipod. then held the rest button on the wireless router for 15 sec. next turn on computer. you will have to re set up the wireless connection (was no big deal). once i had internet on the pc i turned on my ipod and set up the wifi. worked perfect!
Nov 27, 2009 | Apple iPod touch
Wifi On ipod Touch
quit being a cheap *** and get a new router
Nov 25, 2009 | Apple iPod touch
My ipod wont connect to wifi at my house but will at restaurants.
i have that problem with mine sometimes try uninstalling the network and reinstalling it on your ipod , it should find it again, if that dosnt work try a soft resetting the router, once the router has booted up try and get into the network again good luck !!
Jul 24, 2009 | Apple iPod touch
Wifi grey area
Here is a way that solved the problem for me.
Downgrade the ipod touch to firmware 1.1.4. You have to put your ipod into DFU mode ('not recovery mode) and you have to have an itunes version that supports this old firmware. 7.5 oder 7.7 i think.
to load your own firmware you simply hold the shift-button while you push the restore button.
After you have firmware 1.1.4 on your ipod touch, download the jailbreaker "Ziphone". This programm has the option to fix the "no Wifi" problem. Look in the advanced options.
In my case, this was the only thing that solved the problem. I tried restoring it often but nothing worked.
After Ziphone fixed your Problem, you can update the Touch to the latest firmware. Wifi was still working, at least for me
Jul 11, 2009 | Apple iPod touch
I can't get WiFi on my iPod Touch!
Make sure your WiFi connection doesn't have a firewall blocking access to it and make sure security setting say you can share the connection .
Jan 27, 2009 | Apple iPod touch
New ipod touch will not connect to wifi
Did it ever connect to wifi before? I had the problem today and when it picked up the network connection I hit "forget network" and the let it reload, then I re-entered my password (to the network) and it connected perfectly :) Hope this helps you.
Dec 27, 2008 | Apple iPod touch
Apple iPod touch Logo
128 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
