Bosch classixx 1200 wont spin or drain but drum revolves when washing
    President:
  • 1,564 Answers
There are two drive belts, I'm sure one is gone.
Posted on Jun 20, 2009
Drum not turning during wash and wont spin
prob spin capacitor not up on this model
Feb 28, 2015 | Bosch Washing Machines
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
