Question about Saeco VIA Venezia
Not pumping waer but making hella noise
Won't pump water. Will steam however.
  • 1,089 Answers
Hi
Needs to be primed. If you open the steam knob and and you don't get water out, the pump has lost its prime. Check that you hose is in the tank, or has become disconnected inside.
Posted on Jun 21, 2009
Miele CVA615 won't produce steam or hot water. Machine makes a mechanical noise like it's trying but no water comes out. The expel air indicator was on and this preceded discovery of the issue. Steamer...
Trey -
It sounds as if the water pump has gone bad. If the machine will not put water out of the hot water spout or the steam spout, and there is no water in the base of the machine (leaking from pump) then the pump is not putting out any pressure. The sound you hear is the pump running - but no pressure behind it.
Dec 30, 2013 | Miele Coffee Makers & Espresso Machines
Tip
Miele CVA4070 Steam (capucinatore) makes no noise and produces no steam
There are numerous problems where you get little or not steam but you can hear the pump trying to do something, this is often a blockage or a venturi tube problem and you can find numerous posts about how to fix it. If you get no noise at all when requesting steam then it is likely that the steam pump has failed. You can find the instructions to remove the steam pump (and most other components) here:
http://www.cagrimmett.com/justanswer/cva4075.pdf
and you will also find detailed schematics of each of the systems. I removed the back plates as described and found that my steam pump showed clear signs of having burned out while the coffee/hot water pump looked fine.
on Mar 07, 2015 | Miele CVA4070 Coffee Maker
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
If pump does not work then what should i priory
Need more information to solve your problem.
Does the pump come on (do you hear it?) but no water comes out when you make coffee?
When you select Hot Water and open the steam valve, does the pump run and does water come out the steam valve?
If you hear the pump running but no water is coming out - then it could either be that the pump needs to be primed. In that case you would select Hot Water and open the steam valve all the way and let water run out the wand for a minute or two.
If the steam wand delivers water but you don't get any water when you brew coffee, then either the coffee is ground so fine that the water cannot go through the coffee grinds OR the filter disc may be plugged up. Try grinding coarser and try removing the filter disc and cleaning it with a toothbrush - hold the disc to the light and verify that you can see through all the tiny holes.
If it pumps water for coffee but you don't get water out the steam pipe, then the steam wand may be plugged with hardened milk - in that case remove the plastic frother and soak it and clean it. Also use a bent paperclip to clean the hole in the end of the chrome steam pipe.
If the pump doesn't run at all and you don't hear any pump noises ever - then either the pump has failed or has a loose wire.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Steam vac is making lots of weired noise
Possible that the water pump is stuck . worn out and making this noise.
It can be due to clogging in the pump that makes it louder.
So remove the pump to check clean and reset.
Sep 09, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
When the hot water switch is pressed, no water is pumped.
group head is blocked. remove centre screw from the group head remove spring and valve, clean and re assemble.
Sep 20, 2009 | Gaggia Evolution Espresso Machine
'Chugging' noise when trying to get flow of water from steam tube
You must press the hot water/steam button to make sure it is set on hot water. The chugging noise is the pump slowly putting water through the steam boiler for steaming. When you open the steam knob make sure it is all the way open, you will hear the microswitch click when you reach full open(test it out with the machine off). Red light also means heating and low on water, since you are using all the steam faster than it can make it hence the red light.
Jun 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
No water ever makes it through the pump
You have to prime the pump.. Hit the water button and open the steam knob.
If no water goes through the steam wand I would check for a clogged water line.
Ranclio parts and Espresso Machine information
www.CeriniCoffee.com
Nov 19, 2007 | Rancilio Silvia Espresso Machine
Saeco VIA Venezia Logo
391 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
