SOURCE: Eltron 2844 CTP Printer on Ubuntu
I got it working by selecting the Zebra manufacturer, EPL2 driver.
SOURCE: Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
SOURCE: printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
SOURCE: HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
SOURCE: My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
