Question about Homelite Mighty Lite Lawn Trimmer
My homelite trimmer model ut20006 will not run unless it,s on half choke. I think it,s the low speed jet but where is it and how do I get to it thanks
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 23, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
I have a practically new Homelite String Trimmer (model #UT20006 25cc) that has been sitting in the box in my mother-in-law's closet for over 3 years. It will start up like a charm. Fairly easy to crank in...
If all those items you mentioned are ok, then check the Air filter! If it's been sitting around, it may be plugged up or it may have insects that have built nests inside...
Also, there should be a fuel line back to the tank for pressurizing the system... Make sure the gas cap is tight, and the return line is snug in the tank.
Jun 03, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
I have a problem with my homelite ut-20046. It
Run some combustion chamber cleaner (not carb cleaner) through the carb with the air filter off.
Your main jet is partially clogged and it needs a richer air / fuel ratio to run - hence, why the choke needs to be all or partially on.
Hope this helps!
Rob
Sep 27, 2009 | Garden
MightyLite is a Real POS. Brand new and only runs on half choke
Agreed all these cheap trimmers are built at a price the only way to tune them is to take it to the dealer, The special tool costs nearly as much as the machine.
So most machines under 100 dollars are throw away and replace its bs but everything is ending up the same.
Jun 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite 2-cycle gas line-trimmer - It starts okay but when you hit the throttle it dies.
The high speed jet is either out of adjustment or it is plugged. There should be a screws with H (high speed) and L (low speed, idle) You could try to open the high speed adjustment on the carb or run your machine on partial choke if you have to.
Apr 17, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
731 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
