Question about Hotpoint Ultima WF860 Front Load Washer
Error codes Our washing machine (WF860) doesn't finish it's cycle. It stops and displays the codes F04 or F05. I turned it off and then on again and after a while it displayed the code F11. Any Ideas. Thanks Regards - Steve
  • 6 more comments
  • Anonymous Nov 04, 2007
    Exactly the same thing here, any ideas
  • Anonymous Nov 10, 2007
    Someone help F05 error - cant get any clothes out!!
  • Michelle Henderson Dec 20, 2007
    Have the same problem with the WT 960 and can't get clothes out!! Help
  • Jeff Stanton Feb 16, 2008
  • Anonymous Mar 02, 2008
    my maching is (wf860) is also not draing and displaying F5- any ideas???
  • marc1977 Mar 02, 2008
    I have exactly the same problem????????????
  • Lisa Bari
    Lisa Bari Oct 12, 2008
    i have the same problem when i have the dryer on it sop before the end and displays F13
  • kimmham167be Feb 06, 2009
    i had the same problem, took the hose off the back and it solved it, i must say this is the worst machine i have ever bought
    thankyou for helping me to solve it, wat a hard lot of work.
    Problem Solver:
  • 11 Answers
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Posted on Feb 02, 2008
  • PETER HUGHES Feb 02, 2008
    Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
    Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
  • Hambo2000 Dec 02, 2011
    This worked perfectly for me who is a complete novice at these things. Very Simple to do and took about 20mins. Found about a fiver in change and a few hair bobbles in there :-)
  • 4 Answers
Hope this helps least ou will know the fault within the error code here is a complete list of error codes and faults>>>>u can find it here>>>> hope this helps ....please vote thankyou
Posted on Oct 16, 2008
Washing machine (WD860) displays error message F-04 when trying to operate machine. Door closes and opens okay but machine will not start cycle.
Posted on Apr 25, 2008
  • 1,294 Answers
Press "end of cycle" button; wait for 2 minutes or until you hear a distinct click. The door is free to be opened. Till then do not try to open door, ie, dont force it, you will damage the door lock.
Posted on Dec 31, 2007
  • prem mathew Dec 31, 2007
    If that does not work, pull out your exit hose from behind the wall and lay into bucket at ground level. The door shd open. Dont forget to insert the hose back in wall at same height, without pushing it in too deep.
My daughter has a Hotpoint Ultima Washing Machine Model WT741
It starts to wash then stops displaying Fault code F05. What is the cause please?
Posted on Nov 03, 2008
I've had a engineer out to look at my F-05 problem. He told me the code indicates a pump problem. In my case one of my kids chains had blocked the pump, removed it and worked fine.
Posted on Oct 09, 2008
Hi all, I've got the same problem with my WD860 (cycles failing on F-05 and occasionally F-04). I took the back off to follow the advice already given, but I'm not sure that what I saw tallies up with the advice offered above. There was only one (silver) jubilee clip, and it wasn't readily accessible, the other clips were all plastic things that looked breakable. I wasn't sure what pipe I was meant to be removing from where in order to get at the ping-pong ball. I took a snapshot of what I could see and it's here if anyone would like to take a look and offer some advice.
Posted on Oct 05, 2008
  • 5 Answers
Cleaning tehtennis ball cage worked for me and I found 25p and a hairclip. I've now told my kids to cut off all thier hair.
Thanks for the help
Posted on Apr 16, 2008
I have exactly same problem. my clothes are stuck inside the machine
Posted on Dec 11, 2007
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Mar 28, 2015 | Washing Machines
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
Mar 05, 2010 | Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a kenmore front loader 41744072300 that has error code f04. After replacing the keypad because of an F05 error code. Washer stops after 6 minutes on any cycle. Sears states f04 may be the panel is...
After 2 more sears repairmen. They replaced, motor control unit. Wrong.. Then the computer control board.. Correct.. Did not wait for the Repairman because they may break something else. Only took 1 month to figure this out.. Sears = Bad
Dec 28, 2009 | Kenmore Washing Machines
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WD860 machine has stopped mid cycle displaying f-04 I have taken the panel off the back and cleared out the tube from the drum by removinng the clip but this has not worked. On thurning the...
f04 is a pressure switc problem.
take the lid off and check the clear plastic hose is attached to the bottom of the pressure switch, a round part with wiresand the other end to the sumps breather tube.if it is and there are no holes or splits in the tube it may need replacing.
Feb 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
2,050 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
