Question about Sub-Zero 690 Side by Side Refrigerator
My subzero 650 is flashing EC 24?
What is the recommended action?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Hold alarm key for 15 seconds to clear control and clean the condenser. If the service light comes on call for service as you most ;likely have a leak.
Posted on Aug 05, 2009
  • 71 Answers
Better call a tech. ec 24= check for proper ohm reading of defrost heater. replace heater if defective. or check the the thermistor(location) and remount correctly
Posted on Apr 02, 2010
  • 725 Answers
Make sure the condencer in clean. it is on top behind the grille... turn the unit off/on button if the ec34 comes back have a tech check the evapator for leaks...
Posted on Sep 19, 2009
How do you reset the subzero unit after cleaning coils
Hold the alarm pad for 15 seconds. Then when it comes back call an authorized servicer.
Jul 02, 2014 | Sub-Zero 632 / S
Flashing ice light service
Along with the service light, are you getting any fault codes with it (like EC and a number)? Under normal conditions, this would mean the the unit as a whole is running too much and needs to be cleaned. If cleaned and this is still an issue, you may need a certified person to look for cooling issue that only the computer is seeing. This can happen in a unit the is about 10-15 years old, normally in the fridge section. Do you have a ice ball or frost on the the back wall of the fridge section around the meat slide shelf? this would b a tell - tell sign of a cooling issue. If in doubt, call SubZero dIrectly at 800-888-7820 ask for a certified dealer to take care of you. Not every service company can work on the SubZero unit. (You want certified!)
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 10, 2013 | Sub-Zero 650 / O Bottom Freezer...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Vacuum condenser message flashing
Your evaporator needs replacing. covered under 12 yr. warranty parts only.
Jul 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Feb 20, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
471 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
