Turn your
H350 on by pressing and holding the black "Talk" button on the side
of your headset. Hold it until the blue status starts to flash. To turn the
H350 off, simply hold the talk button until the headset turns off. Pair your
headset with your cell phone by entering into your cell phone's bluetooth
menu--Menu > Settings > Connection > Bluetooth Link > Setup (see
Resources below). Put your
Motorola H350 into pairing mode by holding the "Talk" with the device
turned off. Hold the button until the status light on the side of your headset
begins to flash, and turns back into a solid blue. Back in
your phone's bluetooth menu, choose the option to "Search/Discover"
bluetooth devices. And when your phone recognizes your H350, select the headset
and enter "0000" as the passcode.
on your phone open your bluthooth section and(1) turn on bluetooth. then in the bluetooth options, (2)have your phone ready to search / find devices. (3)on the h350 press and hold the power button for about 5 seconds until the blue light comes on and stays on. it is now in paring mode. (4)tell ur phone to search for devices. your phone should find it. (5)then select the h350 on your phones found devices list. they will now pair. its possible a password will be requested, i believe the factory default password for the h350 is 1234. your phone password may be the same as your phone unlock code or your voicemail code. time is limited you may have to do this a couple of times before they actually pair together.
to put the h350 in discovery mode , hold the main button down until the light stays on solid , it does take several seconds , and there is a window time limit , get your phone ready and put h350 in pairing / discovery mode , see if your phone picks it up . if you need help with the phone ,
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Not being cheeky buddy but I have the same pairing are you tapping in "0000". Also go into settings and headphone or carsettings and set to auto answer.
Hope this helps M8
follow the steps to get your product paired.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step above.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H350.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
When your headset is successfully paired with
your phone, the blue indicator light changes
from steadily lit to flashing.
additional help
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
all the best
sreejith
