Question about Refrigerators
Have a GE arctica SxS model PSC23SGRCSS with dispenser not working. have just now replaced motherboard and dispenser control panel with no result. any ideas what else to do?
We checked the wire connections that run through the freezer door, along with the water line, under the fridge. we found that the white wire was badly corroded and not making contact with other connections in the terminal. we clipped the 3 pin wire harnesses from each end, and stripped the ends of the wires. we reconnected blue-blue, white-red, and black-black, using sodder. we then insulated each connection with electrical tape, and used electrical tape to shield the unit from the water line. it worked! i don't think that either the motherboard or display control panel were defective to begin with, but we just left the new ones in place.
Posted on Jun 21, 2009
I have GE Arctica Profile fridge, PSS25MGMCC, that needs cleaning in the ice/water dispenser area. It is very dirty up in the dispenser, I would like to take it apart to clean it. Any ideas how to take...
Please follow these instruction to the letter to avoid replacing control board parts. Unplug refer from wall, then there are two tabs under the control panel to the dispenser (there is holes and inside the holes are plastic tabs the must be slightly push in to release control) once released there is only two screws on some models holding this together, other only had tabs that release the plate. The whole things slides out and thats it, again unplug the unit to avoid shorts and reassemble in reverse order. Any question please ask.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 31, 2013 | GE Profile PSS25MGMCC Arctica 25.4 Cu. Ft....
GE Arctica Refrifgerator- Not cooling
its either the ptc overload on the units compressor is bad and is easily replaced by unplugging the old and replacing with a new replacement,the only other thing it may be is the cold control for setting the temp of the freezer/refrigerator,but normally these don't go out
May 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile refrigerator, PSC23SGRCSS not working
I have the same problem with the same model. Did you ever find an answer?
Aug 30, 2009 | GE Refrigerators
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
