Question about Saws
Looking for instruction manual for rockwell dadao blade 34-960 . cant figure out how to adjust it. it was my father inlaws before he passed. and have never used it.
  • 34 Answers
MANUAL MAY BE AVAILABLE ON INTERNET-
ENTER MAKE AND MODEL NO. OF UNIT ON
INTERNET.
Posted on Jun 21, 2009
I am looking for a manual for a Rockwell Sports Model RK7453 band saw?
Home Depot has the Use and Care Manual for the Rockwell RK7453 on the product page: http://www.homedepot.com/p/Rockwell-2-5-Amp-9-in-Band-Saw-with-59-1-2-in-Blade-and-Work-Light-RK7453/202791039 . Look on the right side of the page as you scroll down. The direct link to the manual is currently: http://www.homedepot.com/catalog/pdfimages/45/459477a0-deee-4b28-aff3-713b3db859fd.pdf .
I hope this helps.
Jun 08, 2017 | Saws
How to change blade
You can download manual on bandsawmanuals.com or try to search on google , make sure to key in the model number of your bandsaw. You can also follow instructions from this article. How Do You Change Band Saw Blade
Jul 10, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Rockwell instruction manual
Check this site . They offer free manuals . This site lead me to a website that provided custom weld service for band saw blade. And I got two blades for not more than $25 .
Apr 29, 2013 | Saws
Rockwell blade runner manual
Try Googling (Rockwell)(RK7321)(manual) without parens.
Jul 21, 2012 | Rockwell RK7321 Blade Runner with Wall...
I have an old rockwell 14" bandsaw and am having
Follow these instructions, but before adjusting the guides see the link below.
It sounds like you have not correctly adjusted the guide blocks that ride on either side of the blade, both above and below the table. These small rectangular blocks can be adjusted by loosening the allen set screw in the guide that holds them in place. They should be pressed in against the blade lightly, without deflecting the path of the blade out of square to the table. (You may first have to sand the ends of the guide blocks square if they are grooved from use. Use a belt sander and a pair of vise grips to hold the blocks while you square them off.) Anyway, the guide blocks should allow the blade to run smoothly, (you might hear a tick tick of the weld passing through the blocks), but will not allow the blade to deflect from side to side. Correctly adjusted, they keep the blade aligned with the bearing behind it, and prevent the problem you describe.
Only after you have correctly adjusted these guides just behind the set of the teeth, and the blade is turning freely by hand when you spin the upper wheel, do you bring the bearings in to kiss the back edge of the blade. Make sure the bearings are lubed to spin freely with a little bearing lube or wd40, then bring both the uppper and lower bearings in until they almost spin or just barely spin when the blade is turned by hand. When you exert a little pressure during cutting they will then hold the blade in place between the guide blocks, so the blocks don't wear the teeth away. Please see this link for detailed instructions I gave another user. (possibly also here) They will apply to your saw as well. If you have any questions or further probelms, write back. You may also wish to check here for a pdf manual for your saw.(check both rockwell and delta).
If you take some care to properly tune the saw, you will get much beter cuts and the saw will be a joy to use.
Nov 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
Jan 08, 2010 | Delta Masonry Tools
Manual or info on a rockwell 28380 14" band saw
I can't find one for the exact model number you have, but there are a lot of manuals for the same era bandsaws available as PDF downloads at this site. Perhaps another manual for a similar machine will help answer most of your questions, in lieu of the correct one...
Have a look around there, though, at both the Delta and Rockwell listings, as I just made a quick look to find yours and there might be something there somewhere.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 05, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Need owners manual for a craftsman band / need help troubleshoot
Hi, On all bandsaws, it's the pitch of the wheels that determine the position of the blade. The top wheel should be adjustable for pitch, and blade tightness.
The blade should only contact the thrust bearings when you are cutting, not when it is idling. No sense in wearing out the bearings and blade while idling.
Dec 15, 2008 | Saws
Saws Logo
141 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
