Question about Soundstorm 500.2SL Car Audio Amplifier
ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2
ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2 2 OHM 12 KICKERS CVR DONT KNOW HOW TO WIRE THEM CAN YOU HELP PLEASE
    President:
  • Soundstorm Master
  • 1,114 Answers
For a 1ohm load it's positive to positive and negative to negative run 1 wire from one speaker to the other. Positive to positive neg to neg. Then 1 wire from the speakers to the amp. The amp will have + - + - on it's inputs for left and right speakers (if stereo) Use the outside positive and outside negative. If there are any switches on the amp that say "mono" "stereo" switch to "mono". Hope this helps
Posted on Jun 20, 2009
How to bridge two l7 kickers
It depends on the end ohm load you are trying to achieve. If your amp is rated at 2 ohms stable, then wire for 2 ohms, if 1 ohm stable wire for 1 ohm. EX. A dual 2 ohm woofer can be wired with the positive of 1 coil connected to the negative of the other coil, then connect the amp to the other two open terminals. This cuts the load of that speaker down to 1 ohm. When connecting the other speaker in the same manner, the two speakers a 1 ohm each add together to produce a 2 ohm load at the amp. NOTE- a 2 ohm amp running a speaker wired for 1 ohm will not have enough resistance to limit the power coming from the amp and runs a high chance of burning the amp up.
Oct 30, 2010 | Kicker S15L7 Car Subwoofer
I have 2 kicker l7 wanting to wire to best olm with hifonics 1200 mono
the best way to wire it is @ 1 ohm, but your amp has to be a 1 ohm stable amp. i'll attach some pics for you. this wiring depends on what ohm your subs are.
Option #2
2_2ohmdvc_2ohm.gif Wiring Option #3
2_2ohmdvc_8ohm.gif Option #2
Feb 26, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Soundstorm 500.2SL Car Audio Amplifier Logo
288 people viewed this question
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
