Question about Standard (CRT) Televisions
Teac 80cm tv no picture or sound just ticking sound
Tv working fine then next time attempted to turn on have power light and ticking sound but no picture or sound
  • 3130 Answers
SOURCE: TV starts but Does Not show picture or no sound
The Tic Tic sound is a result of the high voltage shutdown circuit. Thats what the circuit does if theres a short in the Highvoltage sweep. like maybe a shorted horizontal output transistor??. The only way to really tell is go in and measure the start up voltage and if the Hivoltage comes up and shuts down its a fault in the shutdown or Hhv regulation circuit . if it dosent come up at all then the faults in the Horizontal sweep circuit . Hope this explains a bit? good luck
Posted on Jun 04, 2006
SOURCE: my tv will not turn on
I took my TV apart and solved the problem on my own. For those of you that have basic electrical skills and can solder it is an easy fix that only takes about one hour. I removed the rear cover and pulled the left side board which houses the flyback transformer, easily identifiable by the big orande wire coming off of the top. If one looks carfully the soulder connection will probably be broken or loose which can be caused by movement or heat. I resoldered all of the connections for the transformer about 12 and the grounding wire to the left, a single black wire that plugs into the board. Once this was done I put ti all back together again and no problems since!
Posted on Mar 18, 2007
SOURCE: RCA HD52W55 No sound no picture
Have you solve the problem?
Posted on Sep 29, 2007
SOURCE: centrex 80cm locked
Had the same problem with the same TV. Hold down the DISPLAY button for 5 seconds or more while the TV is on.
Posted on Dec 22, 2007
  • 822 Answers
SOURCE: tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
Posted on May 25, 2009
  • 221 Answers
SOURCE: no picture or sound
Check the power supply circuit for dry electrolythic capacitors (assuming that occasionaly it works)
Best of luck
Posted on Jun 25, 2009
0 characters
1 Points
My sony trinitron is blinking red and won't turn on
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Upon powering on my Toshiba 36" I get the normal.......
first of all have a nice day..the problem of your tv is a COLD SOLDER meaning there's only loss solder causing by overheated component such as resistor, tranformer etc. check and look closely to all of the suspected terminals, someting looks burning, try to solder all the susupected terminal using soldering iron and solder. chek also components it maybe cracked resisitor or diodes
Jul 30, 2009 | Toshiba 27A33 27" TV
Tv won't power on, stand-by light blinks 6 times continously
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sharp 2DR-S100S Ticking sound, will not turn on
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Feb 22, 2009 | Sharp 25R-S100 25" TV
Philips HDTV does not turn on
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
No picture, then no picture and no sound
if your could hear a slight ticking (tick-tick tick) or whining then some electronic component might have been damaged (shorted). if you have no experience repairing electronic equipments then i suggest you to send your TV to a service station!
Nov 14, 2007 | Toshiba 27AF42 27" TV
No Picture, No Sound...Please Help
The most common problem this set has is the Horizontal Output shorting, usually caused by the High Voltage transformer drawing to much current. Whether it's the high voltage circuit or the power supply, having a tech look at this set would not be cost effective. Start looking at the newer technology. Hope this helped.
May 12, 2007 | Samsung TXN2771HF 27" TV
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standard (CRT) Televisions Logo
154 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
