Question about Dryers
No heat gas dryer
Smelled something burning 2 weeks ago. Dryer was still working. Now it is not heating up at all. Cleaned out all the lint from the whole dryer-help
    President:
  • 1,564 Answers
Is this a 220 volt or a 110 volt? If it's a 220, make sure both fuses are good if not it's time for a new dryer.
Posted on Jun 20, 2009
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
1. ) not heating up / cleaned heating sensors mounted on the lint vent holder with ALCOHOL last week ....we had an ink pen in the load ...since then /subsequentially its not heating up...? could that...
If you use a flashlight and look down the filter housing you may be able to see the scock and remove it with a coat hanger.
Rotate the drum both ways with you hand while looking if you cant see it.
Dont worry about the sensors they are ok.
No heat?
May be several things...
Plugged vent
Bad ignitor
Bad gas valve coils
Bad main pcb.
Jan 18, 2010 | LG DLG3788W Gas Dryer
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
Kenmore elite HE4 electric dryer
If this is a Kenmore Elite front loader, taking the back off isn't going to tell you much. The heating element is inside the dryer under the drum on the right hand side. More than likely you have an accumulation of lint on the heating element housing and its beginning to smolder. Running the dryer on low will not change the fact that you have lint in close proximity to a glowing element. It will still burn. Here is a link you can look at that gives you some advice on dryers:
http://www.fixya.com/support/r385301-thorough_dryer_advice
You will need to unplug the dryer and remove the lower panel under the door to gain access to the heating circuits. If you have lint backing up into the dryer, you need to investigate why. If its been a while since you've inspected your dryer ventilation ducting, it would probably be a good idea to do so. Everything is in the link I provided for you. I hope this helps.
PS Conitued running of a dryer in this condition can cause the heating circuits to overheat and fail and/or cause a fire.
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
