Question about Raymarine C80 GPS Receiver
Scanner not reponding - Checking HW
My Radom - Radar system on My C80 raymarine  keeps telling me this message even though i have renewed the cable.
Can anyone advice please ?
  • 43 Answers
1.try with a new software 4.29
if you have an old one like 2.14 you have a problem.
2. After this try you C 80 on a nother boat or Raymarine dealer
than you will know if the C 80 works
Posted on Oct 13, 2009
Can't get radar on the screen
do you have the radar receiver or you just clicking on radar and wondering why you cant see it
Sep 01, 2013 | Raymarine C80 Multifunction Display
C80 GPS
Please remove the power cable form the unit and wait for 30 min then replug it switch on ,,let me if your facing the same problem again...............
Jul 07, 2008 | Raymarine C80 GPS Receiver
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
Hi, I have a new C80 that came in a pre-packaged system with a dome, cables etc. My service department at the marina installed the system. When we power up the radar...no image, power is good, dome is...
Sounds to me like the wiring is not quite right, as though a ground is not properly grounded. It should not be grounded to the battery. Check out the picture of the install below and verify your connections.
http://www.raymarine.com/raymarine/SubmittedFiles/rs125/rs125_legacy_connections.gif
May 15, 2011 | GPS
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
No fixed postion has ? over gps icon in upper right corner of unit
touch lower right hand corner and see if it reboots software. will probably lose all info saved
May 30, 2009 | Raymarine C80 GPS Receiver
Signal on my tom tom
I have a raymarine C80 three in one GPS,Radar,depth sounder....no signal or scanner from radar on sreen it has power.
Mar 02, 2009 | Tomtom One XL GPS Receiver
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
Raymarine C80 GPS Receiver Logo
436 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
