Question about Micrografx Computers & Internet
Micrografx Designer 6.0 will not properly export jpg images.
I try to export a Micrografx Designer .dsf file to a .jpg format and all is well except the .jpg file contained in the original .dsf file overlaps itself 10 to 16 layers so the resulting image is useless. Until recently, the export process worked as advertised but something has happened. Any ideas will be appreciated.
C-Dog
  • 84 Answers
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Posted on Feb 18, 2008
SOURCE: kvt 719 can't change background image
Guys,
All you need to do is save the pic's on a usb memeory stick and plug in to your usb extension on the kenwood. Make sure that you have selected Tuner as a source, go into user interface screen and proceed as instructed in the manual. Solution 1 is the way fwd as it worked for me. You can not load pic's/images from CD.
Posted on Mar 21, 2008
virtualhost
  • 2185 Answers
SOURCE: result very red
is there enough black ink on your cartridge?
try installing a new one.
Posted on Jul 23, 2009
dzenizo
  • 22 Answers
SOURCE: Zebradesigner for xml ''error in processing zpf and lvr files''
Somehow, the correct printer driver is not installed when setting up Zebra Designer for XML.
To fix it, clck on "Start->All Programs->Zebra Designer for XML->Add Printer".
A wizard opens, select "Next" and choose the printer you are designing labels for. Click on "Next".
Select "Update existing printer driver(s)". The driver gets updated and voilá!, now you can export your label desgins.
Posted on Aug 07, 2009
  • 10406 Answers
SOURCE: I am getting an error
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Posted on Jan 27, 2011
How do I export image as jpg format for the web?
hi,
just go to file=> save for web and devices and there select jpeg as output format and the quality...
cheers
mich
Jan 07, 2015 | Adobe Photoshop 7.0 for PC
Save GIMP image as jpg
Press CTRL+E, type in the file name you want and add the '.jpg' or '.jpeg' extension to the end, deleting any other file extensions. Then navigate to where you want to save it and hit Export. From there, its just an issue of importing the .jpg image from wherever you saved it, into Publisher.
Nov 23, 2012 | Computers & Internet
I can't convert file PDF to JPG how i can do ? you can help me?
Just do file > export > image > jpg as in the image bellow: 6_20_2011_5_53_32_pm.jpg
Or this link might help: http://www.makeuseof.com/tag/6-ways-to-convert-a-pdf-file-to-a-jpg-image/
Jun 17, 2011 | Adobe Acrobat 6.0 Professional for PC
I have been using Micrografx Designer 3.1 in Windows XP for several years now. Recently, however, I have discovered that I cannot add text to a drawing. When I attempt to do so, I get the following error...
I had the identical problem on a netbook whose OS was WinXP Lite. The solution that worked for me was to reinstall the OS, this time using the full WinXP. Thereafter no problem.
Micrografx Designer 3.1 remains an excellent drawing program that was designed for Win 3.1 but works fine under Win XP, but not Win 7.
Feb 23, 2011 | Micrografx Designer Power Pack 3.1 Full...
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i...
Close Designer 9.
Jan 27, 2011 | Micrografx Designer 9 Full Version for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
I have images in .ppt format that I would like to upload to facebook. Is this an acceptable format?
.ppt is the extension for PowerPoint presentations, so it's not really an image format. This is why you willnot be able to upload it on Facebook.
However exporting the images from the .ppt is very easy! Just follow these simple steps and you will have your images exported and ready to be uploaded.
To export your PowerPoint slides to other file types (BMP, WMF, JPG, PNG, etc)
  • Open your presentation and choose Save As from the File menu.
  • In the Save As Type dropdown listbox, choose the file type you want to save.
  • Give the file a name and click OK.
  • PowerPoint asks whether you want to export just the current slide or your entire presentation. The question is worded a little oddly, so read the message carefully before clicking Yes or No.
When you save the entire presentation rather than a single slide, it uses the name you give it, makes a folder of that name, then creates the exported files in that folder, giving them names like Slide1.jpg, Slide2.jpg and so on.
Mar 29, 2010 | Computers & Internet
I want to print a simple jpg file in a zebra Z4M, i have been readind the manuals but it seems that we can save (in memory) forms or formats, then call them and print them, but i want to print an actual...
u can print an JPG file easily with zebra designer . just choose the image and print.
if you don't have zebra designer, u can download it at www.zebra.com
Feb 11, 2010 | Zebra Z4M Printer
Mar 19, 2009 | Zebra Z4M Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
Computers & Internet Logo
274 people viewed this question
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
DEEPAK KUMAR SAHOO
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
