Question about Toshiba 23HLV85 Television
No video Powered on screen seemed darker than normal then flickered off. Sound still comes through just no video image.Tried the component hookup and hdmi same problem. When turned on the screen image changes to a dark grey, I think it is suppose to be blue? Any help on common problems would be great. I saw parts on ebay I could buy for it LCD Control Board 6870C-0021C. Thanks for the help. James
  •  James
    James Jun 20, 2009
    This is a tv with a built in dvd player being used to play xbox 360 on. No pc is being connected to it.
    President:
  • 1,564 Answers
First before you spend crazy money on a new monitor try updating your video card driver.
Posted on Jun 20, 2009
  • Dana Newcombe
    Dana Newcombe Jun 20, 2009
  • Dana Newcombe
    Sorry, I misunderstood having dealt with computers all my life, that's where I go.Time to consult with the manufacturer, I know that's a pain in the ***, but they just might come up with one of those ..."Just push this for ten seconds and...." You never know? Good luck.
Tv screen flickers then turns black. has sound but is very faint.
The power supply may be failing, leading to video instability.
Nov 01, 2017 | Polaroid Televison & Video
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
Goodmans gtvl32w27hdf - screen is flickering and picture is darker than it should, but sound is fine. Have tried turning off and on. doesn't matter what channnel you're on and its the same for video so i...
It is most likely the screen backlight. LCD TVs have thin fluorescent lamps and a part called an inverter board which is a transformer similar to a light ballast.
Inverters are typically a $50-100 part and are trivial for any technician to replace. The backlight lamps themselves tend to go pinkish when near the end-of-life, and are a low-cost part, but it requires a lot of work to change the lamps.
IF the LCD display itself is good, then the screen image should remain perfect and undistorted...if the backlight fails altogether, you should be able to see the image by shining a bright flashlight directly on the screen (only as a test, not as a long term solution, obviously :) )
Oct 16, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Flickering and screen dark
sounds like the lamp on one side of the monitor is going out.
It is repairable depending on how tech savy you are.
Sep 03, 2009 | Computers & Internet
The left side of my Dell inspiron screen is darker than the right. Changing the brightness only changes the brightness proportionately. any suggestions
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 23HLV85 Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
