Question about Samsung SGH-a737 Cellular Phone
My samsng slider a737 got wet and says download please help
So far i have tried putting it in rice using a fan and blow drying it but nothin seems to help can some please help me!????
  • 439 Answers
How long did you leave it in the rice? you did remove the battery and cover during this right? You should leave it in minute rice for 24-36 hours up to 3-4 days.
Posted on Jun 23, 2009
Help! I accidentally washed my Hunter ceiling fan remote. It was mixed up in my sheets and it went into the washer with the laundry. I retrieved it and dried it. I know the battery works because I put it...
The electronic parts inside the remote are not sealed. Water is a conductor of electricity and has changed the way the circuits need to function to control your fan unit.
Remove the battery & place the remote in a sock and fill a large bowl with uncooked (dry) rice 1/2 way. Put the sock in the bowl on the rice and cover with more rice. Wait a day or two.
The dry rice will act as a sponge - and attract the moisture from the remote completely (this works for anything that shouldn't get wet (cellphones, etc.).
After allowing the rice to absorb the moisture, remove the remote & discard the rice. Install the battery and try again. If it still doesn't work, you'll need to replace the remote.
May 17, 2013 | Dryers
Water damage
Turn off the Phone...take out the battery and finde a good sized bag of Rice. Rice Absorbs Moisture!!!!! Im serious try it or look for moisture absorbing packets and put it in a small box for a gew days with the phone in it. Try this and it should help..otherwise if you know how to take apart the phone, do this carefully and use a hair dryer to dry out all the water. Once the sensistive components get wet your prett much done for...time for a new phone....but in some cases you get lucky and you get away with little or no damage at all...Good Luck to you!
Jun 18, 2010 | Samsung SCHU960 Cell Phone
What does the download mean on a wet Samsung phone?
if your phone has been wet it will normally stop working, in some cases, sometimes your phone will work for a while, if you know how to do this then take your phone screws out and leave all the bits i a hot place (ie; a drying cupboard) for 24 hours then put your phone back together after wiping all the connections making sure theres nothing interrupting the board or connections, then switch on your phone and it should work perfectly, as for the "download" erm... dunno really try take it to your nearest market, they should be able to tell you what it means.
Sep 07, 2009 | Samsung SGH-a737 Cellular Phone
My phone got wet
Try removing the battery, using a blow dryer to air everything out in battery compartment. If there are any tiny screws or way to open up the phone itself, open it up, and blow everything inside there too.
Let it dry out completely and then see if it will work again. My guess is no, because once the circuits get wet, they are pretty much damaged and irrepairable.
Hope this helps at least some. Good luck!
Jul 31, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Samsung sgh-a737
You need to place the phone in a bag of rice for 24 hours. This usually works to get all the moisture out of the phone. I hope this trick helps.
Jun 23, 2009 | Samsung SGH-a737 Cellular Phone
My web slider got wet how do i fix it
Most common thing to do with this is to take the battery out and keep your phone completely without the battery and back connected. Then, put it in a bowl of rice for 24 hours. If you do that and you continue to have problems, you need to get a new phone. Water damage is the worst thing that can happen to a phone its like the chocolate for dogs- you can't allow it to happen. Try the rice trick, DO NOT blow it with a blowdryer as that can fry the hardware. Hope i've helped you.
Apr 04, 2009 | LG KG800 Cellular Phone
LG viewty Water in touch screen
if your phone gets wet, putting it in a bowl of dry rice over night is supposed to dry it out. hope this helps. :)
Feb 10, 2009 | LG KU990 Viewty
Water damage on samsung sgh-a737
I had the same problem, when download came up i charged my phone. then i took out the battery and put back in and turned on. it worked but some buttons did not. so i pressed hard till it could recieve it and it did and now its fixed!
Dec 26, 2008 | Samsung SGH-a737 Cellular Phone
Water damage
I had the same problem, so i kept taking the battery in and out and turning it on when the slider is down and after about 15 times it turned on but now the numbers dont work right like 4 is 1, 5 is 2 so post wat happens to yours
Dec 25, 2008 | Samsung SGH-a737 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
148 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
