Question about IBM Wheelwriter 30 Typewriter
Space Setting How do you change the space between word settings (12, 15, 11)? thanks
  • Anonymous Nov 07, 2007
    IBM quietwriter 7
  • IBM Master
  • 3,594 Answers
As Jim said the spacing is set by the printwheel to change it you must change the wheel.
Posted on Dec 28, 2007
  • 478 Answers
The pitch is automatically selected by the printwheel.
Posted on Nov 17, 2007
Go in camera setting and change download setting one to other
Dec 16, 2014 | Audio Players & Recorders
When I save a new gprs setting, it shows a msg as memory full.......or 'no more than 70 sets allowed.
Welcome to FixYa!
To be able to save the new GPRS settings, you need to free some space. GPRS settings occupies a significant amount of space and can only be saved in PHONE MEMORY.
Free some memory space by deleting text messages, pictures and mp3's in your phone memory or transfer it to your memory card.
Thank you for using FixYa. Have a great day. Jas247.
May 19, 2011 | Cell Phones
Setting clock how do you set year you have space for two numbers Thank You
Please explain detail. If there is only space for two numbers it would be the last two numbers of the year so 2011 would be 11
May 12, 2011 | Televison & Video
I've music edition . i've set my msg setting as memory card. & presently there is free space of around 5mb but did'nt recd msg it shows there is not enough space delete some data. so what to do now?
maybe the free space you are pertaining to is the phone memory. if you have a memory card in your n70 device. go to menu navigate messaging press the options and then choose other settings. Under "memory in use" change it to Memory Card or vice versa and check if the problem still persists
Mar 25, 2011 | Nokia N70 Smartphone
There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer. Step one: Check the virtual memory settings Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue. Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties . Click the Advanced tab. In the Performance section, click Settings . Click the Advanced tab. In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive. If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over. The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box. The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting. Change the settings as necessary to conform to the information in this step. Click Set , and then click OK . Try printing again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files Follow these steps to run Disk Cleanup. Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean. Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report. Select the following items from the report: Temporary Internet Files Downloaded Program Files Recycle Bin Temporary Files Click OK . If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Remove unnecessary software programs Follow these steps to remove unnecessary software programs. Click Start , click Settings , click Control Panel , and then click Add/Remove Programs . Select a software program to remove, and then click Add/Remove . Repeat these steps for all software programs you want to remove. If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Mar 03, 2011 | HP PhotoSmart C4280 Laser Printer
10 pt printwheel printing 12 pt spacing
Some type styles do have thinner print than others. The pitch is automaticly selected when you change printwheels. You can measure the pitch by printing 12 letter "i" and putting a ruler up to it.
12 spaces per inch is elite and 10 is pica.
Nov 19, 2008 | Lexmark Wheelwriter 1000 Typewriter
Pc problem
Try freeing some space using Disk Cleanup. You can also try deleting files stored in the history through internet options.
May 08, 2008 | Computers & Internet
Ww302 indexing
There is no line space setting other than 1, 1.5 & 2, if tou are typing on a preprinted form it may be out of registration (6 lines to the inch).
Dec 20, 2007 | Lexmark Wheelwriter 1000 Typewriter
Brother ml 100
when the typewriter is first switched on the typewriter will automatically set a margin 10 or 12 spaces in,depending on which pitch setting you have. To set a margin say on 20,space-bar in to 20 on the spacing scale and then press Margin Set Key. to set a margin on say, 5 first depress the Margin release key and back-space 5 spaces in and then set then margin as before. Remember that the typewriter will "forget" the settings as soon as it is switched off.
Oct 29, 2007 | Brother ML-100 Typewriter
IBM Wheelwriter 30 Typewriter Logo
48 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
