Question about Dryers
I do not know how to change belt - Dryers
  • 770 Answers
This can vary from dryer to dryer, but most are basic, with slight variations of this set-up. The belt goes around the drum and around a pulley on the motor shaft. It then routes thru a tensioning device, usually between the motor pulley and the drum on the bottom. The drum is held in place front and rear by the cabinet itself. You will have to remove the front panel to get the belt around the drum. In order to remove the front panel (door panel) you will have to detach the top. It is usually held in place by a couple of screws in the rear, then you can bump it forward and pull up. You will then notice how the front is attached. Be careful to replace the drum (exactly) as it is or it will not turn properly.
Posted on Jun 21, 2009
I would like to know the interval change of my timing belt on my Jeep Patriot Sport 2.0 2008
I must presume you have verified that you do indeed have a timing belt and not a timing chain. (I'm reasonably certain you have a belt, I think the 2.4L engine uses a chain.) Your owner's manual should specify the replacement interval, typically 60,000 or more commonly 80,000 miles. If you're coming up on the 80,000 mile mark, change it. If you bought it used and it's over 80,000 and you don't know if it's been changed, then change it. If that's an interference motor, it will destroy itself if the belt breaks. When having the timing belt changed (or doing it yourself), it's a good time to change the water pump (even it it's fine....simply because you have access while changing the belt), all hoses and other belts. It just makes sense to do these other things while you are doing (or having done) the considerable disassembly / interference removal required for the timing belt work. Shop around and get the required parts, take everything to a mechanic you trust or take a couple days off work and do it. I don't know you or your level of expertise, so my apologies if I'm preaching to the choir.
Oct 12, 2014 | 2008 Jeep Patriot
How do i change the timing belt? how do i know if it needs changing?
the belt is changed every 60,000 miles, there really is no way to know other than mileage if it should be replaced, if u are not sure replace the belt, if it fails it can damage the engine
Aug 18, 2010 | 1991 Mazda 626
I have a o6 scion xb they say i need a belt change i need to know how many belts r there too be change i thing they said i need too change the tranimasion belt
there is no such thing as a transmission belt just look under the hood i believe there is three belts but you can count them under your hood
Nov 03, 2009 | 2004 Scion xB
2004 sebring convertible
YOU CHANGE TIMING BELT EVERY 60,000 MILES 90,000 KM, CHECK YOUR TIMING BELT COVER FOR LAST MILEAGE BELT WAS CHANGED .
Oct 23, 2009 | Cars & Trucks
2000 VW 2.0 Beetle - Manual say not to replace timing belt?
General rule on most cars with a timing belt is change somewhere between 80K and 120K. On some cars, failure of timing belt will destory the engine.
If car is only worth $2500, and labor (parts are cheap on this usually) is $1000, if you can't do it yourself, need to decide if you risk it.
Are you willing to throw away the car when the timing belt breaks? Or spend the $1000, and have some other failure that renders the car useless 5000 miles later?
This is really a financial decision you have to make. If engine blows, you may be able to get $500 for it from junkyard, and you still have your $1000 saved from not changing the timing belt.
Aug 05, 2009 | Volkswagen New Beetle Cars & Trucks
HOW TO CHANGE THE BELT ON A BELT SANDER
There is a lever on the side of the unit, flip the lever and then slid the belt off.
Jun 13, 2009 | Makita 9404 4'' x 24'' Belt Sander
Timing belt change on 2002 lexus straight six cylinder engine.
how do i know when to change timing belt what are symtoms!
Apr 02, 2009 | 2002 Lexus Gs 300
Timming belt
from 90,000 to 105,000 miles, also consider the water pump along with the belt.
Mar 14, 2009 | 2003 Honda Civic
Squileeng with the belt
I need to know why you changed the power steering pump and the belt. It sounds like you had a problem and replaced the wrong component. You chould change whatever component is locked up behind the pulley and replace the belt. Let me know if this helps.
Jan 15, 2009 | 1991 Chevrolet Caprice
Timing belt
i have a 2002 p t cruiser how hard is it to change the timeing belt
Oct 21, 2008 | 2001 Nissan Quest
Dryers Logo
52 people viewed this question
Top Dryers Experts
Marvin
Marvin
