Question about Philips 9P5544C 55" Rear Projection Television
Aspect ratio and tv type
I have dish satalite HD and not sure what to put the aspect ratio or tv type on I have a 55 in. rear projection phillips magnavox.
  • 2 more comments
  • unciviliz_ed Jun 21, 2009
    it says it is a HD tv but it will only work on 430p on the dish box, unless i put the tv on video 1 instead of Y Pb Pr?
    the model # is 9P5544 C102
    I guess you don't know the difference between HIGH DEFINATION and DIGITAL, I know it isn't DIGITAL but it is HIGH DEFINATION
  • unciviliz_ed Jun 22, 2009
    well then the makers lied cause it has HD on the front, guess it must have been a selling gimick, but that explains why it only works on Y Pb Pr with the dish box set on 430p, thanks for the info.
  • Philips Master
  • 8,617 Answers
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Posted on Jun 20, 2009
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jun 21, 2009
    whats the model number of your set as the 9P5544 is a PTV840 Chassis which is a analog TV
  • Sonny Berry
    Yes thats the PTV840 Chassis which isnt a HD Chassis its just standard definition ( Analog ) Only the DPTV chassis are HD
  • Sonny Berry
    Download the user manual from retrevo.com and you will see its neither High definition or Digital. It has what are refered too as digital Connections which mean a digital source which has its own tuner can be connected to your set. But its still a analog ( standard Definition) TV
  • Sonny Berry
    Sonny Berry Jun 22, 2009
    Yes they shouldnt have put that on the set as it does need an external tuner to be plugged into the digital connection. That was one of the transitional sets as the sets were made full HDTV after the PTV915 Chassis when the chassis's switched to the DPTV series.
Change the aspect ratio
you can set the aspect on either remote. the best thing to do is set the proper aspect on the tv remote for regular (sd) channels, and then again for hd channels. the tv should remember these aspect settings and revert to them when you switch back and forth from sd to hd. if you have satelite, there is usually another aspect on there you can change depending on the program, but i usually recommend leaving it alone. if you are on an hd channel with side bars, switch to the sd version instead of changing aspect so you dont have to keep flipping it back and forth.
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have only partial picture. top of screen cut off.
check the aspect or ratio settings
there is a button on the remote called aspect, ration, pic size, or something simmilar you need to push.
if you have satelite tv, it can also be the format button on that remote
May 21, 2010 | RCA P55000 55" Rear Projection Television
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
Hdtv
hi! might be best to call Uverse so that they could guide you thru setting the right aspect ratio for your TV. hope this helps!!! goodluck!!!
Mar 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Picture not to edge of screen
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My tv the picture is bigger than the tv screen
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Oct 20, 2008 | Akai PT4298HD Rear Projection Television
Fullscreen HD?
check to see if the box has a tv type setting in it's menu since I don't know what the model of the HD box is it must be in the user manual on how to set this up. it is not the tv that is the problem.
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Feb 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Hdtv
From the info that I have been able to find out. your set only has the 4:3 aspect ratio so its not A HDTV with only the standard aspect ratio
Jan 18, 2008 | RCA P52926 52" Rear Projection Television
Philips 9P5544C 55" Rear Projection Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
