Question about Garden
Craftsman Lawn Tractor will only run in full choke
I have a craftsman 18HP (Briggs&Stratton) DYT 4000 (Model 917273634). It sat over the winter with a little gas in it. Ran fine when I put it away. Now when I start it, it only runs when its in full choke and sputters even then. I've removed the carb and checked all the jets and passages, they're clear. I know its fuel related because I've gotten the engine to run by spraying carb cleaner into the intake throat. This way it runs wherever I put the throttle. I'm aiming know at the filter and pump. Any history of this engine losing vacuum for the pump? Is there a one way check valve from the tank to the pump? I ask because I cannot get air to blow back into the tank.
  • jrhii Jun 25, 2009
    I checked clearance on all the jets. Another thing I tried I checked is that the solenoid on the bowl was working, it was. I changed the filter and still have the same problem. It just seems like its not getting enough fuel. I'm going to run a separate hose into a gas can and see if the pump draws it up. If not, perhaps I'll change the pump.
    President:
  • 1,564 Answers
When you had the carb off did you clean the low jet with a welding tip cleaner? This solves most lawnmower hibernation problems. Next year empty the fuel tank completely and spray a little WD40 or an eqivalent into the tank and plug hole.
Posted on Jun 20, 2009
  • Dana Newcombe
    Dana Newcombe Jun 20, 2009
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Briggs & Stratton 19.5 HP engine
just had the same problem found the internal jets in the carb plugged took it apart and soaked it for a couple days runs great now
Apr 22, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
449 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
