MODEL M7DH65B2A*A-R. Acts like it's not getting power but it is.
I removed the back and am looking for some sort of reset or fuse. I see no sign or smell of anything burnt. Fan spins freely
UNplug it and let it sit for about 10 to 15 minutes and the built in circuit breaker will reset. The probable cause is the compressor can not start up due to the pressure in the lines so the breaker kicked in to prevent damage
Was this helpful?
Yes
No
Popular Solutions for Fedders A7DH65B2A Dehumidifier
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
