Question about HP Pavilion zd8000 Notebook
Keyboard overheating When I leave my HP Pavilion zd8000 on for a couple of hours the keyboard gets very very hot. Is this a dangerous condition?
  • mlmatera2 Jun 20, 2009
    It has been a very long time since I changed the battery - I usually leave it plugged in. Where can I find the instructions for changing the battery?
    President:
  • 1,564 Answers
This is a charactoristic problem with many brands of laptops. How long has it been since you changed the battery? Overcharging the battery is what causes the heat to seemingly heat up the keyboard.
Posted on Jun 20, 2009
  • Dana Newcombe
    Dana Newcombe Jun 20, 2009
    Based on the year of your laptop the usaers guide was eithier paper booklet or in your computer, search for the users guide under help and solutions.
How do i get the hotkeys to work on a HP zd 8000 laptop
If you have the remote for the HP Pavilion zd8000 you can use that to switch if the keyboard is faulty.
Feb 05, 2012 | HP Pavilion zd8000 Notebook
"No IDE device" in BIOS drive selftest in HP Pavilion zd8000
any moisture on the motherboard
will destroy components if plugged in
even if yoru laptop is cold in your car , is ok
but when you bring it inside and plug in fast
condensation can burn out the tiny components, motherboard is bad
Jul 18, 2009 | HP PAVILION ZD8000 SEREIS 100GB (4200...
Hp Pavilion zd8000 shuts down loosing all opened windows
There is a software called "SpeedFan" which you can download here
This software will tell you the internal temperatures of the computer (so you can figure out if overheating is the problem). Most of the time overheating is due to excessive dust inside the laptop. The best bet is to get a can of compressed air and clean the inside out. This does require some disassembling of the system, so if you are not comfortable doing so I would advise you to take it to a local computer shop.
Another solution would be to purchase a "Laptop Cooler", this will lower your temperatures anywhere from 5-10 degree's, but can get annoying to lug around with you. You can view some laptop coolers here
If you happen to run the Speedfan application, let us know what the temperatures displayed as, and I can tell you if it is running too hot!
Apr 23, 2009 | Computers & Internet
Problem with the laptop keyboard (HP pavilion zd8000)
is filter keys in ease of access center in control panel turned on?
Apr 01, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 keyboard skips characters
The most common reason that your cursor skips around is that you are touching the touch pad when typing. Some are more sensitive than others. On my Toshiba I had that problem, but it has a Fn key that allows me to turn off the touchpad. Problem went away when I went to a mouse instead.
Had a client with a Dell with the same problem. I had to actually physically disconnect the touchpad and her problem went away.
Now as for the first problem, (the HP), I'd say you have a stuck key on the keyboard. It would make that noise.
Feb 14, 2009 | HP Pavilion zd8000 Notebook
Overheating?
raise it around 6 cm above the table..
Oct 09, 2008 | HP Pavilion zd8000 Notebook
The popular keyboard problem in another form
Take the key off and check the depressor. Be gentle and try to remove only the key and leaving the retainer. If the depressor has moved or is stuck in a depressed position, this will cause your problem. If the depressor is good, then I'm afraid your keyboard has malfunctioned and will need replaced.
Jul 19, 2008 | HP Pavilion zd8000 Notebook
Hp Pavilion zd8000
sound like it is overheating. my suggestion would be to use a laptop cooling mat(found at bestbuy radioshak or circuit city)
Jul 14, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zv6000 Notebook PC keyboard replaced
Probably the keyboard you got is defective. I have seen buttons working in very bad conditions. When a key doesnt work or several is bad news.
Try to get a replacement. Since you have already reseated this simply check if the flex cable is properly locked, (ear plugs or similar) and not moving.
Mar 19, 2008 | HP Pavilion zd8000 Notebook
HP pavilion zd8000, Battery not charging
The problems with the HP Pavilion (Particularly the ZD8000) are sadly well-known by HP. It's not a problem with the battery or the charger or anything you can easily fix. The problem is heat. If you search long enough, you'll find hundreds of people with three problems: 1) the battery stops holding a charge after about 8 months, they buy a new one and get the same problem; 2) certain keys stop working on the keyboard, they remove the battery and the keys work again; 3) permanent lines start to appear on the display and never go away.
Unfortunately, there is nothing you can do about these problems with the ZD8000, except stop using it as a laptop and ditch the battery. I have been problem-free since I ditched my third battery and just use it with a power cord.
Last year, I filed a formal complaint with the Better Business Bureau regarding HP's failure to acknowledge this problem and recall the machine. Each time I called service, I was instructed to follow the battery initialization procedure. All this does is allow support to get rid of you for 24 wasted hours, after which you have to call again and talk to some one new who tells you to do the same thing. The problem is, the procedure fails because the battery won't hold a chage in the first place. If you get to the end of the procedure with them after wasted days, they tell you to buy a new battery.
The HP ZD8000 is defective and never should have been released with a Pentium 4 processor. It's too hot and fries the battery and damages the screen.
Jan 26, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
