Getting this error in head adjustment while initializing process.
SOURCE: hardware alarm
One likely cause is a blocked optical sensor . Try these three things, in order, and check the printer after each:
- Pick up the printer, turn it upside down, and shake it. If 40 pounds is too much for you to lift, get a friend to help. Or, better yet, get a friend to do it without your help.
- Using an air compressor with a blow gun attachment, direct air to the paper path entry and exit, and to the sides of the platen. Then look for torn-off tractor feed bits of paper in the crevices. You may need tweezers or needle-nose pliers.
- Take the cover off and repeat the previous step with the air compressor. This is tricky. Use this as a last resort, as the printer may not be usable after a troublesome disassembly. Do this only if you're going to have to replace it otherwise.
SOURCE: TALLY 2250 HARDWARE ALARM WITH 000000128 305
you req to diagnose the initializing of tally 2250 printer. most of case initializing problem occured, aga gears coming out is the main problem
SOURCE: Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Optical sensor Cable was damaged. Replaced it and now working fine.. thanx for your time guys.
