Question about T-Mobile Sidekick® 3 Cellular Phone
Won't Turn On
My sidekick 3 was on, then i turned it off so i can put my sim card in it and when i tryed to turn it back on it wont turn on, i tried charging it and only a orange light turns on but the phone is still off no signs, or anything...
    President:
  • 625 Answers
Remove the battery and let it sit for about 15 minutes and try again
Posted on Jul 28, 2009
My sidekick slide cant read my new sim..........i need help...when ever i try am stuck at the sim center.
Hi, First request the phone's IMEI code by contacting customer service for T-Mobile. If you've been a customer long enough, T-Mobile may send the IMEI code, or the code identifying the specific phone, in a few days.Turn off the Sidekick Slide. Remove T-Mobile's SIM card, which is located near the battery. Insert the new provider's SIM card.Turn the Sidekick Slide back on. The phone will detect the new code and ask for the IMEI code. Enter the code. Now the Sidekick will operate using the new network.
Thank you
Jan 03, 2011 | T-Mobile Sidekick
I turned off my sidekick lx 2009 (off button) and it wont turn on
what i did was take out my sim charg it den cut it on it will cut on put sim bak in afta u cut it off and try again do a couple of time it will work
May 04, 2010 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont receive text messages but can send them.
ok i have a sk 2008 and the samething happend to me, what i did was just turned of my phone took out my batter and sim crd and let it chilled there for a min...then i put it all back together and my phone started flooding with texts...i think a sidekick can get clogged up with texts..i also think that the battery can over heat and thats what causes some problems..so when ever i have a prob with my kick i just take out the battery and let it cool down :] ok hope i helped
Jan 25, 2009 | T-Mobile Sidekick® 3 Cellular Phone
The sidekick 2008 does not turn on !!!
Francisco849,
The same thing happened to me today. I tried removing and replacing the battery and SIM card, then waited a few minutes and tried again. After this didn't work, I called T-Mobile and the lady, Shawn, told me to check the small box to the left of the SIM card. If it's red, you have water damage, and you need to order a replacement. But your Sidekick does have a warranty, just make sure to call them and order a [free] replacement before your warranty expires. Glad I could be of help. :)
Dec 18, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Switched sim card into different sidekick and lost everything?
no ure done dude , unless you try to check main sim contact might be in there
Nov 08, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 wont turn on
I did the same thing with my phone. You have to replace the screen. It has been damaged.
May 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
    Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
    Wont read SIM card
    Try to do a hard reset.
    Flip open screen half way put pin or pen in the tiny hole and hold it in till it vibrate and turns off and on..
    I hope it works
    Nov 12, 2007 | T-Mobile Sidekick II
    T-Mobile Sidekick® 3 Cellular Phone Logo
    75 people viewed this question
    Top T-Mobile Cell Phones Experts
    Starnley Johnwells
    Starnley Johnwells
    ismael castillo
    Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
