Question about GE GSH25JFR Side by Side Refrigerator
Freezer doesnt work right
My GE side by side frigerator sarted making loud noises and shooting ice out of the dispencer all on its own with no one touching a thing
    President:
  • 1,564 Answers
There's an arm that sits over the top of the ice tray. See if you can get it to stay in the raised position and then wait a day to see if this has helped. If not, The switch to which this lever is connected is most likley no good and has to be replaced.
Posted on Jun 20, 2009
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
GE Profile Refrigerator freezer not working right & ice in refrig
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Loud noise in freezer & ice buildup, too
Turn off, defrost over night doors open turn back on will work ok Regards Advisor
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
125 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
