Question about Yahoo Messenger
My messenger breaks up and has a delay on pc to pc conversation it keeps flashing low wifi signal
Reinstall yahoo messenger. if the problem still remains then i guess ur wifi has a very low bandwidth.
Posted on Jun 20, 2009
Keeps dropping WiFi signal!!!!! How can i prevent this from happening?????
Move to a place where the signal is better. WiFi only drops out when the signal becomes too weak.
The other possibility is a break in service from your wifi provider. When the wifi drops, quickly look at the wifi signals available, and if your is not there, take a quick screenshot. When you have 6 of them, contact your provider and complain.
https://www.google.ca/search?q=How+can+i+prevent+&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=_xzMWLOVMqOC8Qesh504#q=how+can+i+prevent+wifi+signal+dropping&*&spf=191
Mar 17, 2017 | Computers & Internet
How do you delete messages from yahoo messenger, need to keep others out of my business
    1)Launch yahoo messenger and sign in, click "messenger" and select "prefernces"
    2)Select "conversation history" and click "view conversation history"
    3)Click on contacts name on left side, scroll through chat history on right side until you locate the conversation you want to delete/ click the "trash" icon that appears when youhover over the conversation, and click "delete"
Oct 04, 2015 | Yahoo Messenger
Can phone calls be made using messenger on facebook
From the Facebook Help Center:
How do I call someone from Messenger
To make a call:
  1. Open a conversation with a friend.
  2. Tap g">. If the icon is gray, you can't currently call this person.
Keep in mind that you may not be able to call people if their phones aren't connected to the internet. Placing calls through the Facebook or Messenger apps may use your existing data plan.
Hope this helps.
Mar 04, 2015 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
My free signal keeps breaking up
if i understand correctly your talking about wifi? if you are and your using your built in wifi card than you can go to bestbuy buy a WIFI USB adapter by NETGEAR and select the strongest card... the MSRP is usually above $80 but the range is guaranteed to reach i hope this helps
Aug 26, 2014 | Computers & Internet
When I plug something into the usb jacks of my e6590 asus, the wifi signal goes out and i have to run a troubleshooting to get it back on. is this a common problem?
The Asus website has no model E6590, you need to check the model again.
But no, plugging in a flash drive should not drop your WIFI, plugging in a bluetooth, WIFI dongle. could cause a signal break.
Mar 27, 2013 | IBM ThinkPad Computers & Internet
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal.
This is a message that yahoo messenger usually tell the users when it detects a low internet connection. You are right with what you have mentioned about the weak wi-fi signal.
I have been receiving the same message because of my wi-fi signal but so far so good. I never have any problem with the quality of the sound in the call or any disconnection of the call except for the sloppy webcam. But, I understand the problem because I really do have a low signal at home.
Apr 02, 2011 | Yahoo Messenger
At low input,repeats from dd3 are clean but when guitar is cranked repeats are unpleasantly distorted.How can I cure this?
You are probably overdriving the pedal. Reduce the amplitude INTO the pedal and AMPLIFY it more AFTER the pedal.
When digital conversion is done from the input and the input exceeds the input voltage capabilty of the A-D convertor, it effectively "flattops" just like your overdrive on a guitar amp.
Your guitar may be very "hot" having high output. One needs to keep the signal levels in-bounds of what the hardware can handle at EVERY point.
May 13, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Blue light flashing
It means that your WiFi signal is on and your console is on standbye mode. You will get updates, etc 24hrs a day automactically if you setup your console "WiFi ON", even when the system is not actively on. The blue lights flashes when it receives a update or any type of news. Change your settings and your problem will be fixed.
Mar 26, 2009 | Nintendo Wii Console
HP WEBCAM DOESN'T WORK WITH INSTANT MESSENGER
Are you using Flash Player on MSN? This sounds like you need to turn on access from the flash player setting menu. This sounds like another issue with the latest update of flash player. Also, you might try 'unchecking' the box for 'use hardware acceleration' in the flash player settings.
Apr 26, 2008 | HP Pavilion dv6000z Notebook
Yahoo Messenger Logo
75 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
