Question about TruTech KLV3112 10 in. LCD TV/DVD Combo
How to preset radio stations on trutech KLV3112
I know how to scan the FM radio stations, but don't know how to preset them, lets say, "Station 1: 95.5FM", "Station 2: 97.5FM"... please help
4 Suggested Answers
SOURCE: comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Posted on Apr 29, 2010
micromatikal
  • 2777 Answers
SOURCE: trutech klv3112 How do you change the time?
On the remote there should be a MENU / SETUP button which allows you to go into an on screen menu that includes the TIME setup.
I used to own this exact device and have set the time before this way... I am trying to find the actual manual for the unit so I can give you step by step instructions but I remember it wasn't all that difficult. Just go into the setup menu and look around, you will definitely find it.
Thanks, let me know, just reply to my answer here and I can help more
Tim
Posted on Nov 07, 2010
  • 159 Answers
SOURCE: It's not a problem ...
Hi, it will be in the 9 to 12 volt range probably with about a 2 amp rating. Buying the kind of " universal " power supply with interchangable plugs should do the trick. The actual " adapter " you buy will more than likely be marked as follows 100-240v~ 0-12v dc ( or a solid vertical line over dashes) 2.5a followed by a polarity indicator. Always be careful too when inserting new plug-it should fit snugly but not so that you need to push with much force. thanks for letting me try to help, I hope this was of some assistance. Good luck, Prodzilla
Posted on Apr 13, 2011
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Programming FM tuner preset buttons
scan for the station when you have the station hold the number button you would like the station to be on in until it flashes when flashing leave and push memory or dont push memory and wait until it stops.
Dec 28, 2013 | Audio Players & Recorders
How do i set my preset fm stations
Should have numbers 1-6 on your radio faceplate.....go to the station you want and push and hold button 1.....it should blink, then stay lit again...that preset should be programmed......go to another station then hit number one.....is your station programmed????? If it is go and do that to 2-6 and you should be gd 2 go...let me know if that helps........
Mar 25, 2012 | JVC Car Audio & Video
How do I preset different radio stations?
Hello
There are 6 preset position available for each radio band.
For programming, Radio must be ON. Tune to a station. Press MEMO/DEMO. Press any button 1 to 6. The tuned station will be memorised on the number you select by button press. Repeat using a new station and preset number. There is no atu preset option available with this device. You have to store stations you want according to your preference. Only 6 station positions for each band [total 12 positions] together with AM and FM bands.
To recall the stored stations, press the desired number 1 to 6.
Dec 07, 2011 | Sharper Image SI785 Clock Radio
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
TruTech KLV3112 10 in. LCD TV/DVD Combo Logo
93 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
