Question about Q-Logic QLE4060C-CK Network Adapter
A/c works while driving not while sitting still
A/c works ice cold when you drive but while sitting at idle it blows slightly cool
  • 57 Answers
Thermostat might not working automatically. Try replacing the thermostat.
Posted on Jun 30, 2009
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
No heat blowing cold air
Heater blowing cold air? - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan.../233563-heater-blowing-cold-air.html
Nov 5, 2006 - 15 posts - ‎6 authors
... it idle, all guages normal, heater on HOT and HIGH, it blows cool air. .... thatNissan put out for some reason (I have no idea where it went to, ...
How To Fix Your Car's Heater - YouTube
? 3:03
https://www.youtube.com/watch?v=bmmn4ON_t0c
Nov 26, 2009 - Uploaded by Scotty Kilmer
... Scotty Kilmer shows how to fix your car's heater for those coldwinter ... How to Diagnose and Fix No Heat Issues - Also a Demonstration on ...
maxima blowing cold air while idling - Maxima Forums
maxima.org/...maxima.../599527-maxima-blowing-cold-air-while-idling....
Sep 21, 2009 - hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving. ...Not sure whats involved in a heater core for the Max, but I had to pull the ...
Jan 15, 2016 | Halonet 95-99 NISSAN MAXIMA / 96-99...
Suburban overheating and air conditioner blowing hot
If you have a viscous fan hub have it replaced as it is not working. The problem you have is that the engine is not driving the fan to draw air through the radiator when idling so the engine overheats . When moving the air flow from driving cools the radiator and so the temp goes back down. If you have electric fans have the codes read to find the fault or check why the electric fans are not working.
Jun 17, 2013 | Chevrolet Cars & Trucks
My 2007 jaguar x type ac starts blowing warm when car is idling. what could be causing this?
make sure the cooling fan is working if so the freon charge could be low
Aug 26, 2012 | 2007 Jaguar X-Type 3.0 Sedan
2003 Lincoln LS hot air while stopped cold while driving
Hello
Based on what you have said and my 30 years a Ford dealer tech I believe you have a slightly low AC system refrigerant charge due to a small leak at the AC compressor or the AC line connections. I would have a shop hook up a set of gauges to monitor the pressures at idle and see just how low it is. DO NOT ADD UNTIL YOU KNOW HOW MUCH IS NEEDED, YOU CAN LOCK UP THE COMPRESSOR.
Jul 09, 2012 | 2003 Lincoln LS
My heater, when parked and idle, cools down. The heater will heat again once I begin driving, but this is freezing me as I sit and wait for my kids at school. It blows cool air while I am parked and will...
It could be the electric fan is going on too easily.
The radiator and hoses should be almost too hot to touch.
And when cold, the fan should not really do on at all.
But the thermostat could be opening too soon also.
There are two hoses to the radiator, and when you start a cold car, only one should slowly get hot.
The other should stay cold until the thermostat opens, after the engine is good and hot.
If both start slowly getting warm at the same time, then you need a new thermostat.
And also make sure you have enough coolant in the radiator.
Dec 20, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
2004 SATURN VUE HAS PROBLEM BLOWING COLD AIR WHEN SITTING IDLE. IT WILL COOL IF I AM DRIVING AND GIVING IT GAS CONTINUOUSLY. FREON OK. CHECKED OUT BY MECHANIC WHO REPLACED THE "EXPANSION VALVE". STILL...
did you check if the cooling fans are working? this is very important, because they lower the pressure of the freon before passing throughout the expansion valve and getting into the evaporator,more pressure means highter temperature, , of course when you are driving the air flow throughout out the condenser lowering the freon temperature in the condenser and lowering the freon pressure at the high side, tha's way the temperature inside the car is lower ... you can have a similar problem if the condenser is partially plugged..hope this was very helpful...
Aug 05, 2009 | Saturn Vue Cars & Trucks
Heater blows cold air unless accelerating
1.maybe your thermostat is no opening or closing.
2. not enough Ant-Freeze
3. Low on water
With more details on the engine i may be able to help you more. for example what is the temp reading after it idles awhile or does it blow warmewr when driving ?
Dec 30, 2008 | 2000 Oldsmobile Intrigue
No cool air when idling..
The refrigerant level may still be to low or the compressor is not working properly.
Sep 02, 2008 | 1996 GMC Sonoma
Q-Logic QLE4060C-CK Network Adapter Logo
98 people viewed this question
Top Q-Logic Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Q-Logic Computer and Internet Expert? Answer questions, earn points and help others
