Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Hi there i have a troy built honda engine 2500 2.3 pressure waqsher and can not get it started. it will start for just a moment and then just die. almost sounds like it isnt getting gas but ive checked lines changed gas n spark plug. Any ideas?
  • 1,041 Answers
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. You can also use the Den Tek Brush to clean the jet in carb. if it has one. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 25, 2009
    Did this solution solve the problem?
    Jim
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Hard to pull start rope on troy built 020337
i would check the shear key on the flywheel but first reset valve clearence
Apr 16, 2014 | Briggs Stratton 020273 Elite Series...
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
I can start it but then it quitsi i have a troy bilt honda engine power washer that will start but then quits what am i doing wrong
sounds like the fuel pump which are made cheap. Temporarily mount gas tank up higher should do the trick. I hung my tank on handle, to lazy to replace pump so left gas tank hanging works fine.
Aug 30, 2009 | Karcher 2500 PSI Pressure Washer
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
May 05, 2009 | Karcher 2500 PSI Pressure Washer
8HP troy-bilt will not start, this is my 1st time this year
Hi
Try changing the plug with a new one with the same heat range.Priming the engine(put some gas in the cilinder through the plug hole)and start the engine.
best regards savumihai71
Jan 28, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
189 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
