Question about Pioneer VSX-94TXH
Issues with Pioneer VSX 94TXH receiver
1. Using a Scientific Atlanta 8300HD set top box, the HDMI connection will not work. No audio or video goes through the receiver, and the HDMI indicator on the front blinks every so often, I assume to establish an unsuccessful handshake. Because of this, I'm forced to use component cables for the video and optical for the audio. This generally works, but see problem 2.
2. For all component video sources (cable, Xbox console), we sometimes experience snow/video noise on the TV at random times. The only way to remove this noise is to switch the input select back and forth on the receiver to reset the input and then the video is fine. This does not happen in any predictable fashion, but it's still quite annoying. This does NOT happen with my Blu-Ray player, which is using an HDMI connection into the receiver.
FYI - the video output from the receiver is HDMI-to-DVI to the TV. While I'm curious how to resolve issue #1, I'm more concerned about how to resolve #2.
  • 7 more comments
  • gs_scooter Jun 20, 2009
    While I accept the advice of checking with the cable provider about the HDMI port of the set top box, the rest of my question(s) weren't really addressed, especially issue #2 with the occasional video noise for component video sources.
    Understood about the insignificant difference between HDMI and component, but still looking for help on video noise issue.
    One reason for excessive noise may using a low grade component video and running it accross several high voltage wires.
    Thanks for the response. Could you please go into more detail on this? I'm not completely following you here.
    Understood. Unfortunately, there's nothing I can do for the gaming console since the component cables are proprietary. For the cables from the cable box, is there a particular brand of cable to look for or something that indicates the level of shielding?
    They make simple devices that you can add to interrupt the shield and
    help cancel out noise if this is the problem. You can get them fairly
    inexpensive.
    Could you provide a link to one of these devices so I can see what you're referring to?
    The game console is only proprietary because of the end that plugs into the console, all the rest is the same as any other.
    Right - what I was questioning was whether or not there was anything I could do about the shielding quality of the gaming console cable.
    I don't see an example of the isolator in your post..?
    The components are all plugged into a surge protected strip that's plugged into a 3-hole outlet.
    Thank you very much for this. Do you think it's worth putting the game console through the isolator or is there anything else you think I should look at?
  • gs_scooter Jun 23, 2009
    This thread made the most sense in trying to isolate the problem and get past it. Excellent.
  • 334 Answers
Hey, there, sorry I have to ask the simple questions first. One reason for excessive noise may using a low grade component video and running it accross several high voltage wires. Another problem which may be more likely is a grounding issue on your reciever. Let me know about the wires first.
Posted on Jun 20, 2009
  • 4 more comments
  • seth veloso Jun 20, 2009
    depending on the type of shielding material used in your component cables depends on how well it keeps out electrical noise. Noise from power cables for other devices, radio noise. Also, for each device, all the cables should be the same type and length, otherwise this will throw off the timing of the video signal
    Sorry, my phone rang. If you unplug everything except for your tv and one device that seems to be giving you problems with the component quality, that will reduce the "electrical noise" in the area. They make simple devices that you can add to interrupt the shield and help cancel out noise if this is the problem. You can get them fairly inexpensive.
    sure, let me find one for an example. The game console is only proprietary because of the end that plugs into the console, all the rest is the same as any other. I'll get right back with ya
    Here is an example of an isolator. They do make some with cables on one side so you don't have to buy another set but this is the basic item. Also, just to make sure, you did not bypass or remove any of the ground plugs on your power cables or have a two hole outlet do you?
    Oops, sorry bout that here you go
    http://www.tekcable.com/component-video-...
    You could try to isolate the wires behind your cabinet (try to route them away from your power cables and cable tv cables). If that doesn't work, you have some sort of grounding issue and that device is going to be the easiest way to fix. You can use it on whichever device that makes you want to throw it out the window, game console included. There may be one other thing that I doubt will help but if you are plugging all your devices into different electrical circuits (different breakers in your panel) that can also be the issue but rarely is since all your devices are close together.
    Top Expert:
  • Pioneer Master
  • 81,410 Answers
My cable box has a HDMI port, but it is not connected inside the box, it is the same brand of box as yours, not all ports work on these boxes, I would recommend u not use it, on broadcast TV there is very little diff between HDMI and regular RCA cable connection, the important differences are in DVD, esp Bluray..
    Brigadier General:
  • 3,917 Answers
Make sure you have the cable box set to push signal to the HDMI out. It should default to that hookup when it's active but there's a chance if you had it running off of componenet and moved to HDMI that it needs to be switched at the box from the cable box's menu.
Also make sure you have the TV set to the HDMI input. You shuld not have coax going to the TV if the HDMI is hooked up, unless you are running a splitter BEFORE the HD box to get the analog band in as a second input for Picture and picture purposes.Call TW and make sure that the HDMI port is active. It's possible that they did not activate it under the current firmware version. Although you may not get the correct answer from the customer service rep. Tell them you want to talk to a tech supervisor or someone in converter staging.
Go to the DVD player's setup menu and make sure you output video over the HDMI port.
Due to copy-restriction issues, DVD players can only output up to 480p over component.
After you connect all cables, if you still see no video:
Leave TV on
Turn off the player and then on. This allows the player to recheck HDCP settings with the TV. If it does not work, you have a bad cable. Try unplugging the audio cable, you may be canceling out the signal by having two things plugged into your DVD payer.
-If you have two HDMI cables and your receiver has a HDMI INPUT and OUTPUT you can connect that way for the time being.
-Make sure the HDMI port you're plugging into on the TV is for INPUT. My TV has two INPUTs and one OUTPUT.
-Check your TV and DVD players user manual and if you don't have one download it. My TV or my PS3 required a special set up in the menu when I decided to use the HDMI. Thanks for contacting Fixya
  • e-Guru
    e-Guru Jun 20, 2009
    try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial .
    Thanks
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
DVI / HDMI problem
This problem is almost certainly on the 8300HD side of your setup. URL for the 8300HD, just in case you need it: --> http://www.scientificatlanta.com/products/consumers/userguidepdfs/4013171.pdf Dittos for the TV, just in case: --> http://www.samsung.com/us/support/download/supportDownDetail.do?group=televisions&type=televisions&subtype=dlptv&model_nm=HCN4226W&mType=UM&dType=D&vType=L&cttID=37697 You're using the HDMI-to-DVI cable to connect, and I see that the manual warns on the bottom of page 11 that some DVI connected HDTVs are incompatible to the signals that are output by the HDMI interface. First thing to try - when you change the settings in the 8300HD, in the "General Settings > Audio", see if you have this problem with all of the possible selections, or if it's only with the "Dolby Digital" setting. Since the HDMI also contains the audio signal, it may be interfering with the DVI recognition in the TV. OR - See if you still have this problem when turning the TV on first, then the 8300HD. Or vice-versa. The power-on order of the two devices may make a difference. OR - With the TV on and with the 8300HD off, press the GUIDE and INFO buttons at the same time. Using the on-screen menu, verify that it is set to HD mode. Press the POWER button on the 8300HD when finished. OR - Replace the HDMI-to-DVI cable with a PrPbY/V component cable, available at Radio Shack, Best Buy and other electronics stores. One of these options should solve the problem. If not, you'll have to start sending e-mails to Sci-Atl and Samsung. Hope this helps! ;)
Jul 29, 2007 | Samsung HCN4226W 42" Rear Projection...
Trying to program a universal remote to scientific atlanta 8300hd cable box. I can't find code for remote
If you have a URC-7800 the codes 0477, 0008, 0017 should work for the scientific atlanta cable box.
Feb 05, 2010 | One For All URC-7800 Remote Control
When changing channels, the TV goes black for several seconds
It's a "Bug" in the firmware version 1.2 which is what your receiver uses. Be thankful you have audio and video 100% (even with a delay) The current version 1.3b is functional 100% of the time (so far) The HDMI issue you have can be fixed by a service center authorized by Yamaha under warranty ( if it still is) and they will upgrade the board and software to work with all the current versions. Out of warranty; it's a pricey ordeal. It's not Yamaha's fault or that of any other manufacturer which provides HDMI switching. It's the ongoing battle between the recording industry, and the consumer demand for "choice" It's a "Copyright" issue... Anyway, if it's still under warranty you can send it out free of charge and get it fixed. Otherwise, run your cable directly to the TV with HDMI and use digital coaxial for audio to your receiver. If you need more info, google "HDMI forums" and you can get the whole scoop from all sides involved. Hope this helps
Aug 20, 2009 | Yamaha RX-V663 Receiver
Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Jun 17, 2009 | Sony STR-DE698 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
Pioneer VSX-94TXH Logo
224 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
