HOW DO I GET TO THE MEMORY SLOT UNDER NEATH THE KEYBOARD OF MY LG LE50-3L2Z NOTEBOOK
  • nicodvdk Jun 20, 2009
    Normal
    0
    Unfortunately the memory slot at the back got damaged,
    don’t want to accept memory card any more. I’m now left with only 256mb memory
    under the keyboard which I want to upgrade to 1gb. To remove the keyboard is no
    problem, loosen two screws from the back and then clips on the sides and bottom
    of keyboard. But when keyboard is removed you get to an aluminium plate which I
    don’t know how to remove.
    It is a laptop LG LE50 Express. It has two memory slots one underneath the laptop(which is damaged) and one underneath the keyboard. I can see the memory through a cut-out in the aluminium panel underneath the keyboard. The problem is how to remove the aluminium panel?
The slot is accesible by removing the entire black bottom of the laptop (a bad design issue, btw), so the best you can do (if you havn't solved this yet), is to take the laptop to a suitable place that not just sells the DDR memory, but where they can also install it, and, if you condition your buying the memory to having it installed on the laptop, they will probably do it for the same price, after all, they want to sell!, or at the most, they'll do it for a few extra dollars, which will save you from the teddious (ans risky) task of disassembling it yourself. You can also request a quote for repairing the damaged slot, maybe it's not too expensive. Good luck! Richard.
Posted on Oct 05, 2009
  • 484 Answers
Bad news is that you need to remove the keyboard from your laptop to get to the memory slot. Have you looked at the bottom of the laptop to see whether there is a port to the memory under there? Memory usually is much more easily reachable than to go through the keyboard first.
Posted on Jun 20, 2009
  • 1 more comment
  • Alex Howard
    Alex Howard Jun 20, 2009
    Forgive my confision. Is this a desktop or laptop? Desktops don't usually have memory slots under the keyboard. Laptops don't either, as most of them are under a port on the bottom of the laptop case itself.
    If that area is damaged, and you are left with no other place to add memory, you can use a large USB Jump Drive to augment a Vista laptop, but that will not really solve your problem. It soulds as if you need to have your laptop professionally repaired, so that the memory module will fit in the laptop again.
    Sorry for the possibly bad news.
  • Alex Howard
    Alex Howard Jun 21, 2009
    Have you looked to see if the aluminum panel you speak of is accessible from the bottom of the laptop? You can see it under the keyboard, but it may only be removeable from the bottom of the laptop, where the other memory goes.
    I really am not familiar with this machine. I would recommend going to the manufacturer's web site and searching for a manual for that model laptop, as there must be a diagram in the manual to help you figure this out.
    This is all Google shows for that model laptop:
    http://www.google.com/search?hl=en&q...=
    See if it can help you.
  • Alex Howard
    Once again:
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
How do I install memory that's under keyboard on d830 latitude
Lift up 1 side of the keyboard cover with a small flat screwdriver.
Remove keyboard cover.
Remve three screws securing the keyboard.
Lift up the keyboard and placed it on the display panel or palm rest, so you can accss the memory slot A. The keyboard is attached to the mboard via a flat ribbon cable.
The memory slot A is located just abve the touch pad buttons.
In order to remove the existing memory module carefully spread latches on both sies of the memory slot.
The memory module will pop up at a 30 degree angle.
Pull the memory module from the slot A by the edges.
Install new ram and put everything back together.
Done!
Sep 10, 2010 | Dell Latitude D830 Laptop Computer PC...
I cannot find the second memory slot on the sony vgn-a290 laptop.
The second slot is under the keyboard. There are three small clips at the front of the keyboard. You can release them with a small screw driver.
May 27, 2010 | Sony VGN-A290 Notebook
I can only find one slot for a RAM module, under the memory bay door on the bottom of the machine, but the Crucial site says there are two slots. A system info readout for it says I have 512 of RAM but the...
The other memory slot is under the keyboard. Below is the service manual that has the full disassembly instructions for thelaptop. You can see the memory module installation on page 83. Just follow the guide on keyboard removal, the slot will be visible when the keyboard is removed.
http://tim.id.au/laptops/thinkpad/T40-T40p-T41-T41p-T42-T42p.pdf
Nov 04, 2009 | IBM ThinkPad T40 2373 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Is there another memory slot under the keyboard?
how to check the Ram slot location
1) most laptop have two slots at back, so no other slot under the keyboard
2) some laptop has onboard Ram(on the surface of motherboard) ,if you see one slot at back so no any slot under the keyboard
3) if the laptop no any slot at back it should be one or two slot under the keyboard
your laptop no ram slot under the keyboard
hope it help you to improve your idea
May 09, 2009 | Computers & Internet
Can only find one memory slot/bay for my Inspiron 1720, correct?
The other slot is under the keyboard. You have to remove the top plate then remove the two screws and lift up the keyboard.
Mar 08, 2009 | Dell Inspiron 2200 Notebook
Memory module
There is a cover on the bottom of the machine that the memory is under. If there is only one slot under this cover, then the other slot will be under the keyboard. There are two memory slots on this machine, and it will hold up to 4g of memory.
Aug 28, 2008 | Acer Aspire 5610 Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
Computers & Internet Logo
129 people viewed this question
Alun Cox
David Payne
David Payne
