Question about Dell 0JM629 Inspiron 1520 Keyboard
My screen can only be seen under a bright light. Can it be fixed?
    President:
  • 2,653 Answers
Yes, usually the inverter needs to be replaced.
Posted on Jun 20, 2009
My zeepads screen isn't lighting up. if you turn it just right in the light it can barely be seen. I have tried the back light and the brightness settings on the tablet and the reset..nothing has worked....
If you can see a faint picture on the screen then it is probably the screen inverter is faulty! If it is still under warranty then send it back!
Dec 25, 2014 | Tablets & eReaders
Increase in brightness & sometimes switch to "negative" momentarily
he Dell I'm using also has an adaptive brightness, regardless of the fact it does not have a light sensor. It just changes brightness of the screen depending on how much white/black is shown at that moment. Whenever I switch from a very dark to a very bright website I notice and increase/decrease in screen brightness. I'm running Windows 7 by the way.
Good Luck
Jan 01, 2018 | Samsung SyncMaster 2333SW 23" LCD Monitor
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
My laptop does show light on screen it can only be seen under bright light
It sounds like you require a replacement ballast unit as there is no backlight.
Consult a toshiba dealer or try ebay for parts.
Jan 21, 2011 | Toshiba Computers & Internet
When my m45-s331 laptop is turn on for a long time, if i put the monitor off, maybe in not be turn on again and it's brightness become very low and hardly it can be seen! what should i do?
It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 17, 2011 | Toshiba Satellite M45-S331 Notebook
DLP projector won't show bright images
This unit should be under warranty and can be fixed, also if it is not under warranty, they can also fix it.
check out fixmyprojector.com
Jul 25, 2009 | Mitsubishi XD2000U Multimedia Projector
Light is dimmed. Cannot make it brighter.
This happened to me, too, when I replaced the battery. Turns out one of the wires that affects the brightness came loose. I found the loose wire, touched it to a few places where I thought it should go, and one of them caused the screen to come on to full bright.
I was extremely nervous dealing with this - never soldered in such tight quarters before, but once I soldered it down, the problem was solved. I have other problems with my ique - like extremely limited battery life - but the brightness problem is solved.
Mar 02, 2008 | Garmin iQue 3600 GPS Receiver
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Creative Labs Zen Sleek backlight went out
I think there are brightness controls in the settings, I'm not too sure lol as my player isn't in the room with me. If there are brightness settings, make sure they're turned up and your backlight is not set to OFF. If the problem persists after this, you can get in touch with Creative an I think they offer a repair service if the product is not under guarantee anymore, but if it is under guarantee, enjoy a new player courtesy of the guys down at Creative. I hope this helps^^
May 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Dell 0JM629  Inspiron 1520 Keyboard  Logo
64 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
