Question about HP Pavilion F1703 17" LCD Monitor
Monitor will not turn on - power is on blank screen
  • 121 Answers
Hi
You must first check the connections and if it still dont works the you must take it to your vendor.
Posted on Jun 20, 2009
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Screen blanks out when turning on after two seconds
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Will the power button still be on while the screen is blank? if yes, it means your picture board is malfunctioning.
The picture board on your monitor is bad, since the screen turns blank after two seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | Samsung 19 SyncMaster 192MP LCD Monitor ...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Aug 17, 2008 | HP L1706 17" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
