Question about Hotpoint Aquarius WF000 Front Load Washer
I have an LG fully automatic washing machine. the water pipe connected to it leaks continuously, the pipe is brand new & still the problem persist. Please help fix this issue
    President:
  • 1,564 Answers
Grab a pair of channelock pliers and carefully tighten the hose. Is the leak AT the hose connection, you may have deeper problems.
Posted on Jun 20, 2009
Why is my brand new front loading lg washing machine leaking water from the bottom?
Maybe the door gasket is leaking. Maybe an internal connection is leaking.
Feb 25, 2018 | LG Washing Machines
Model no 6.5kg wf7035dn fully automatic from LG water is not stop automatic so what to do
check the level hose on the side of the tub is connected properly as any cracks or leaks will not transfer the rising pressure to the level control switch to stop the water flow into the machine
It could be a faulty control switch as it does 2 things
turns off the water control when the setting is reached ( low to high level)
and at the same time starts the wash action
May 01, 2016 | LG Washing Machines
What can be done to stop the orange steam nozzle/ water circulator on lg front load washer to stop leaking after wash is complete. machine is brand new
If you washer is brand new, call LG service. They will replace affected part at no cost to you under warrranty.
Feb 17, 2015 | LG Washing Machines
Lg outer drum leak
Basically you need to open the water tap with the washing machine off. If water still flows in, then your water inlet valve has to be replaced. If the level continues to rise and does not switch off, then either there is a leak in the pressure switch pipe or the pressure switch is defectiv(very rarely) or their is a blockage in the hole entering the brum onto which the thin pressure pipe connects.Either of these could be the problem.
Jun 24, 2012 | Washing Machines
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
I need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
May 04, 2009 | Washing Machines
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
My brand new Lg front load washer fills with water after the completion of a full wash/rinse cycle has finished and the machine is turned off.
can be
either
inlet valve leaking. turn off water and see if it still fills
or
if drain is plumbed in to a spigot off the sink trap, every time you empty sink, some of the water goes down the drain pipe. to cure in this case, take the drain pipe as high as possible up under the sink in a swan neck
Oct 18, 2008 | LG Washing Machines
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
