Question about Frigidaire GLRS264ZA Side by Side Refrigerator
When icemaker is filling water comes out door dispenser
I have a Frigidaire Gallery side by side refrigerator. When the icemaker is filling with water, water also comes out the door dispenser. How do I fix this problem?
  • 7 more comments
  • peteorpete Nov 03, 2007
    The complete model number is GLRS264ZAW1. I will check on the water issue that you mentioned as well as the diode and get back to you. Thanks for the response. Peteorpete
  • peteorpete Nov 06, 2007
    You asked if water filled the icemaker when using the door dispenser and it does not. It only happens the other direction, comes out the dispenser when water is filling the icemaker. The diode has been replaced but I continue to have the problem. Any other suggestions. Do you think it's the water valve?
    Thanks so much for your help.
  • peteorpete Nov 07, 2007
    I'll try that next, thanks.
    I had a Technician check the valves and he said while the problem was actually happening he was getting 110 volts to the icemaker valve and 15.7 volts to the door valve. Is this normal? Do you think the replacement diode could have been bad when it was installed? Thanks, Peteorpete
  • peteorpete Nov 08, 2007
    Also, can the diode be tested to see if it's bad?
  • peteorpete Nov 09, 2007
    Do you know of a way to test the diode?
  • Anonymous Feb 03, 2009
    My side by side model makes loud clicking noise, sounds like a woodpecker off and on. In looking at owners manual it states that the Cold Control & Automatic Defrost Control can make this sound.
    Is this a repair I can make myself by replacing this control?
    Am I on the right track or is something else making this sound.
    Please advise
  • Anonymous Mar 17, 2014
    i have a Frigidaire refrigerator that keeps filling up with water under the produce trays
    frigidaire refrigerator keeps filling up with water in the inside
  • 473 Answers
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker doesnt make ice
* Check the temperature setting
* Assure that there is enough room for air flow in the freezer or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condenser coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Aug 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water will dispense from the door but will not fill the icemaker
Me too, same issue. Just changed water filter prior to problem
Mar 17, 2009 | KitchenAid KSBP25FKSS Side by Side...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
375 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
