Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD has no file showing all converted to .chk
I can only see /Found.000\File780.chk (by the hundreds) trying to use a backup file. I have NO other visible files on the WD anymore. This was catastrophic to me and now am TRYING to find a solution.
  • 62 Answers
Your hard drive has bad sectors on it and will need to be reformatted, most of the time the sectors can be recovered for usuable space.
Posted on Jun 26, 2009
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
Tip
How to play Blu-ray ISO backups on WD TV Live
To play Blu-ray ISO backups on your WD TV Live, one thing you should know is that WD TV Live can well play ISO files from a USB drive, while network shares do have problems actually.
In order to get an ISO backup, what’s your workflow? As all I know, some people use tsMuxeR to back up the Blu-ray disc, and then converted it into an ISO using Daemon Tools. Personally, I use Pavtube Blu-ray Copy to make ISO backups for my Blu-ray discs.
Within several clicks, this program can finish its task, and enables you to get an ISO image file. What you should do is just loading your BD files via "Source" option, and then choose "Image File (*.ISO)" from the pull down menu of "Target" to specify the destination folder. BTW, you’d better indicate your USB drive as the save path, or you need spend time to copy the ISO image to your USB drive repeatedly. Once the two steps finished, the backup process will begin, and then you just need wait for the resulted ISO files for your WD TV Live.
As long as copying task is completed, plug the USB into your WD TV, and connect it to your HDTV via HDMI cable, what you should do next is enjoying your BD movies on your widescreen TV leisurely.
One more thing I should mention is that some users have problems to play Blu-ray ISO files via their WD TV, but DVD ISO is working well. Not clear about the accurate reason, but another solution can be recommended. Since WD TV is able to beautifully playback HD MKV files up to Full HD 1080p, thus we just need a utility to convert BD files to HD MKV, and then everything will be OK. Because of the Blu-ray copyright issues, some discs are highly protected, we must take advantage of a powerful application to do so. In that case, the following Blu-ray ripper is suggested, it is able to remove nearly all kinds of BD protections, including BD+, AACS, and even MKB Version > 10 is supported as well.
This Blu-ray ripper allows users exporting "MKV HD Video (*.mkv)" format, and also enables users to reset audio and video parameters via clicking "Settings" button. You can set the resolution at 1920*1080 to remain 1080p quality of your Blu-ray movies, as well as keep 5.1 channel of the original surround sound. All in all, all the parameters like bit rate, codec name, frame rate, sample rate are all changeable in the following interface.
After your preferred settings for your WD TV have been set well, just click "Convert" button to start conversion. Once finished, you can watch them on your TV via WD TV with ease, and the high quality of the Blu-ray movie has never been changed at all.
Is this helpful? Hope it is.
on Jan 29, 2010 | Audio Players & Recorders
Tip
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
Backup:
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
Restore:
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
on Dec 26, 2009 | Computers & Internet
Hello, I have a new WD Elements 500mg
If you are using Windows Vista then format your external drive with exFAT (Extended File Allocation Table, aka FAT64), or NTFS. And if you are using Windows XP then only solution is to format drive with NTFS file system.
How to do that, just right click on HD from My Computer an click format.
Oct 18, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
I own a Data traveler Kingston DT101 8GB. My files are broken in folder FOUND.000. I also tried to scan it with anti virus and error checking but still nothing happened. Files are named: FILE0001.CHK...
Those files are nothing but lost clusters recovered. If the data is very important for you, there is a chance to get it recovered, however, it won't be free. You can contact any local vendor or try the following link.
http://www.data-recovery-usb-drive.com/
regards
Sandeep
Oct 13, 2009 | Kingston Technologies 512MB DataTraveler I...
I have a usb that has 2gb of files I can longer access I know this because in properties it shows that they are there yet when I open it they are not. Windows did something to them when I had the stick in...
is it transcend make. if so go to www.transcendusa.com and avail techsupport. your problem should be solved. they have an online recovery program which can be downloaded and pendrive restored.
s.v.raghavan
Bangalore
Sep 23, 2009 | Generic Memory Electronics - Others
Help to backup full computer programs & docs with WD Passport 160
Try going to the "Computer" icon and look for the external drive. Open the ext. drive folder and look for the InstallSeagateManager icon, the Application one. Double-click on it and it will allow you to install the software to do a backup on your new computer. First thing you should see is the Language Selection screen. I think you can take it from there!
Sep 22, 2009 | Western Digital Passport (WDXMS1600) 160...
Sansa m250 2GB can not see any files or play
I had a similar problem.
This is how I fixed Sansa m250 2GB
I have Windows XP, so if you have a different version of Windows you might have to do something else.
Connect the player to your computer.
From My Computer open the drive that says SANSA M250
If there is no folder called "audio" make a folder named that. (this is where your future mp3 files will be stored).
My audio folder was missing, so I had to do this.
Now go back to My Computer right click on the SANSA M250 drive scroll down the menu and open the folder that says "Open As Portable Media Device".
Now click on the icon that says "SANSA M250"
Now open the folder that says "FOUND.000".
If you are having the same problem that I did all your old mp3 files will show up with a file extension .CHK instead of mp3 and the names will be numbers. You can either erase all these & reload all your songs into the "audio" folder I mentioned previously or you can rename each file extension to a .MP3 instead of .CHK. (after you change them to .MP3 they will load on your mp3 player. But, remember if you do choose to rename them instead of erasing and reloading, when you want to permanently delete them you will have to access the "FOUND.000" folder again to do that.
Dec 07, 2008 | SanDisk Sansa m250 MP3 Player
Identifying files in scandisk
Nov 20, 2008 | SanDisk Sansa m250 MP3 Player
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
145 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
