Question about Sony KDF-E60A20 60 in. LCD HDTV
Hi, My 60 inch Sony projection model # KDF-E60A20. Purchased March of '06. About 1 year and a half ago she started giving me problems. Every 30 secs or so tv would go "black" and no sound for about 30 secs and then back on for about 30 secs and so forth. some times the issue would correct itself but only for days or even a couple of weeks at times but problem always returns. was told by a technician that issue ws not the lamp. was told by Sony that it was the "lamp driver" (power box). bought and replaced it but issue again only corrected itself for a couple weeks then back again. is it in fact the the lamp or can u figure something else is wrong. please help and thanks in advance. Divine
    Problem Solver:
  • 5 Answers
This could be caused by dust on the bulb. Dust can cause the unit to over heat and will shutdown for a few seconds to a minute and then come back on when it has cooled down. This time can vary depending on the location of the unit and the temputure in the house. The dust becomes hot and so the Thermal unit shutsdown for a short while and then comes back on.
Clean the bulb by removing the cage and using compressed air and a micro fiber towel and install back intot he unit. Make sure you follow the Sony Maunal. Also make sure not to touch the bulb as the oils from your skin will cause it to burn out quickly.
Posted on Aug 31, 2009
2 Suggested Answers
  • 16 Answers
SOURCE: kdf- e60a20
http://www.sonysxrdtvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
The unit turns on and off every 40 sec. or so. I have turned the unit off and on and I get a red light blicking 5 times on and off. this happened about 4 to 6 mo. ago and it is happening again...
Below info are related to Sony KDF-E60A20 lcd projection tv.
5 times red light blinking indicates problem with lamp drive circuit (ballast supply board) that is not producing high voltage for lamp to generate high bright white light.
Check/ replace ballast supply board in above mode tv to solve this problem.
If you tv model is different, let me know to provide you related info.
Thanks
Jan 17, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20, picture and sound go out then re-appear every 30 sec
Was it just the bulb or the complete lamp assembly? If it was just the bulb you need to handle it with latex gloves to avoid getting oils from your hands onto the lamp.
Sep 10, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Kdf- e60a20
I may be late with this but it souonds once again ike dust in and on the bulb cage. These TV's will turn off by themselves if they over heat. The extra dust(not much) can/will cause the TV to heat up and shutdown for a few seconds to a minute. Depending on the time of year and location of the TV can vary.
Try removing the bulb and cleaning it with compressed air and a micr fiber towel. Of course don't touch the blub itself as the skin oils will cause it to break.
Jun 20, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60' projection model # kdfe60a20, the picture keeps going out and then back on.
Try taking off the back pannel and spray compressed air on the fand and lamp. There is probably too much dust in the fan and on the lamp, triggering a sensor to go off and you loose your picture. If the sound goes off too, then it my be something more techmical. My tv had the same problem. This is how I fixed it. You can also try replacing the bulb. They are at least half price on the internet than they are if you buy them at a local retailer.
Jan 04, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Sep 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
184 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
