Question about Mustek Gsmart Mini 3 Digital Camera
Cant Set Self-Timer
How do you set the self-timer to work?
0 characters
1 Points
How do I set the self timer on my cannon a560 camera?
Press the self-timer button to cycle through self-timer settings. The rectangle indicates normal shooting, the clock indicates self-timer. Depending on the shooting mode, you may also see overlapped rectangles for continuous shooting.
To change the delay time, select [Self-timer] from the Recording menu.
The self-timer button is the same as the down-arrow on the circular multi-selector, marked with a clock.
Jul 20, 2010 | Canon PowerShot A560 Digital Camera
How do I use self timer. I set in on menu and I
In the REC mode, press [MENU]. On the "REC" tab, select "Self-timer" and then press right. Use up/down to select the timer type and press [SET].
May 13, 2010 | Casio Exilim EX-Z1200 Digital Camera
I need help with setting the self timer on the Olympus Camedia c-700 camera. Can't figure how to do it with the menu. Any help would be greatly appreciated, Thanks
the self timer usually works like this.
find the self timer setting and set it to 5 or 10 seconds.
then exit the menu and click the button that you normally press to take photo. the self timer will start automatically and the picture will be taken after 5 or 10 seconds (depending on what you set).
note that the self timer will be reset to off after this.
Jan 22, 2010 | Olympus Camedia C-700 Ultra Zoom Digital...
I can not set the self timer. In the manual it says hit menue button go to "self timer" select the secons and shot hit "set" hit menu, hit shutter button fully. When I do this the Timer lamp doesn't...
The self timer will not work in the "Easy" mode (icon with a heart in it) or in movie mode. According to the chart in the back of the manual, the self timer should work with all other modes.
Oct 02, 2009 | Canon Powershot SX110 IS Digital Camera...
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
Mar 19, 2009 | Pentax Optio 60 Digital Camera
Can't find canon powershot a560 self timer
when in picture mode, press "set" then go to "drive mode" and choose either 10 or 2 seconds
Dec 03, 2008 | Canon PowerShot A540 Digital Camera
Self Timer
Once you have the self-timer set up, press the shutter release button to activate it.
Jun 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Canon A720 IS self timer
i have no idea.. but i actually have the same camera and i cant even figure out where the self timer is so PLEASE can you tell me? thanks
Oct 24, 2007 | Digital Cameras
Mustek Gsmart Mini 3 Digital Camera Logo
16 people viewed this question
Top Mustek Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Mustek Digital Camera Expert? Answer questions, earn points and help others
