Question about Apple iPhone 3G
Stuck on the apple screen resetting doesn't work, and plugging it into my PC doesnt work either
  • 3 Answers
Assuming you can see the phone in itunes, have you tried a restore from itunes rather than a reset. Also if the battery's flat it can take a while to do anything once plugged in.
If that doesn't work try DFU (Device Firmare Update) mode. Press and hold home and sleep (while connected to PC) then release after 10 secs. (if you see the apple logo that's too long). Should take you through a complete restore.
Posted on Jun 23, 2009
My IPad is stuck with the apple logo on a black screen while resetting to factory settings. No more movement now. What to do?
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Sep 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
When i turn the machine on,the blue screen is on and the keyboard doesnt work
make sure there are no buttons stuck...pull out the plug for thirty seconds and plug it back in.
If that doesn't work check the connections to the key pad.
Aug 22, 2011 | Canon iR 2016i Black and White Copier
Apple logo on screen, thts it.it doesnt do or go anywhere..........
leave it on, so that the battery dies out.........plug up to PC, if Itunes come up check for new updates for iphone 3G........ this should reset it NOTE do not just pull the USB plug out release the IPHONE fron the PC (on Itunes eject the device)
Mar 12, 2011 | Apple iPhone 3G
My iphone 3GS is stuck at the Apple screen. I've tried holding the off and home buttons to reset, but it's not working
This is not a good sign and one of the most common causes with this device. I could tell you a series of troubleshoot.If that would not work, device needs to be send for repair.
Have you tried a hard reset? Hold the Home and Sleep buttons together for 10-15 seconds, until you see the Apple logo come up on the screen. You may need to do this while the phone is plugged into it's charger or a computer, so that it has power.
Usually If it's stuck at that screen, and holding the buttons together for 10-15 seconds didn't help, then there's a hardware issue, and it will need to be replaced.
However, try few more steps
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Or
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Disconnect you phone from your pc leaving the wire connected to your phone not your pc.
open itunes
hold sleep wake button + home button until your screen goes blank...
let go of sleep wake button and continue to hold home while plugging back into pc... should take about 15-30sec and itunes will see your phone in restore mode
IF THIS NOT WORKING
Try rebooting you phone by plugging it into the charger & turn wall socket on
If that also does not work then you need to take it the apple store.. They will replace it or service it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 28, 2010 | Apple iPhone 3G
My iphone is stuck on startup screen with the apple in the middle of the screen, been like that for 6 hours.... tried resetting it doesnt work just does the same thing
Ok, what you need to do is turn the phone off, hold the home key down and connect the phone to the computer that your itunes is on. This puts the phone is recovery mode and you just need to follow the prompts from there. Make sure you are holding the home key when you plug it in from off.
Oct 28, 2009 | Apple iPhone 3G
Stuck ipos in disk mode
Plug it into the computer, and in the ipod's main screen, uncheck the box that says allow disk mode. Hope this works!
Aug 31, 2009 | Apple iPod nano 3rd Generation
Ipod wont rest it is blank with the apple screen
plug it in and then press restore to store settings, like on the screen dedicated soly to your itouch?? then load again, without 3G cuz that may b the prob. if it still doesnt work, take it to the apple store.
Aug 28, 2009 | Apple iPod touch
I tunes screen appears when turned on
you can re set it., hold down the menu key and the arrow key at the bottom... im pretty sure you wont lose all your songs.. if this doesnt work your only other option is taking it to apple
Mar 24, 2009 | Apple iPod touch
My iphone doesnt want to open to the main screen
do a soft reset, push the power button and the sleep button on top of the phone at the same time for about 10 seconds until the apple sign shows up
Feb 18, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
238 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
