Question about Hitachi 42V710 42" Rear Projection HDTV
My Hitachi 50V710 has both indicator lights blinking and does not display any image. Temp LED and Lamp LED. But I hear the fan running and the lamp is the same I've always had. Whats wrong?
    President:
  • 1,284 Answers
With both LED's flashing sounds like a bad lamp to me. Not uncommon for Hitachis LCD projections to have that symptom. Cjeck your owners manual for the light flash code. Good luck..
Posted on Jul 24, 2009
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
My temp light keep blinking
When the temp light is blinking, that indicates that one (or more) of the cooling fan has stopped spinning. The TV will stay off to protect itself from overheating until the fan is replaced. There are two fans. One is available here: http://www.encompassparts.com/products/?GS01131 ; the other is http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/GS00931/New.aspx .
Retrevo has the manual for the Hitachi 50V710 here: http://www.retrevo.com/support/Hitachi-50V710-TVs-manual/id/372ag010/t/2/ . You will need to enter the code to access the file.
I hope this helps.
Sep 14, 2011 | Hitachi 50V710 50" Rear Projection...
Samsunh hlr5067wx no pic lamp led blinks on and off for about a minute then temp and lamp led starts to blink. Replaced lamp already
check your fans. there's 3 of them. make sure all of them are running. Let me know what you find. Does your lamp light up
May 13, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
The tv won't come on it gets power but no picture and on the indicator lights on the control panel only the lamp indicator comes on and just blinks. Did the lamp go out?
The manual says if the lamp light is blinking to check the lamp cover. If it is the temp light that is blinging check that the fans are not locked or shorted.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My infocus X3 projector won't come on, I get a green light at first and then it turns red. What is the problem?
Well the single re blink of the LED indicates Lamp failure. Though most likely there can be a few other causes for your lamp not lighting. here's the most likely problem if the lamp has not failed.
It could be the lamp power supply (ballast) has failed.
Or if you don't hear the fans running either there is a possibility the "over-temp" sensor has failed.
If the fans are running I would try replacing the lamp.
Take Care!
Oct 16, 2009 | Nview Z215 10.4" LCD Panel with Video(16.7...
Hitachi 50V500
Sounds like the lamp has gone or the filter needs cleaning.
Aug 21, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 42V710 42" Rear Projection HDTV Logo
175 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
