Hi, after the service, replacing the filter and emptying the old oil and adding new oil. The mower does not start with manual or electric.
Comments:
Jul 11, 2009
- Hi Jim,
I used last fall. Then for winter I emptied the oil and the gas. Now, a few weeks ago, I put new oil and gas. I also, replaced the filter. I charged it for two days. Now this is the condition:
-key start does nothing when I turn it.
-the rope start after a few try which, the first one, had a little blue smoke coming from the side no longer works. Even the the rope no longer re-tracks.
I though it might be the spark plug but I do not know how to replace the spark plug; I bought a new one.
I thank you for your help. Any help will be great. I need to fix this so I can use it.
Regards, --jh
Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked. You can also use the Den Tek Brush to clean the jet in carb. if it has one. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
For a Toro S-200 Showblower, is there a drive belt for the paddle barrel or is it a mechanical...
(More)
For a Toro S-200 Showblower, is there a drive belt for the paddle barrel or is it a mechanical linkage? Is there a diagram to show me where it is and how to repair/replace it. Thanks a million - John
lawn mowr ,will not start with key. switch is good,batt is good,switch at eng is good. how do i get...
(More)
lawn mowr ,will not start with key. switch is good,batt is good,switch at eng is good. how do i get to starter motor? i wash every time after i cut.
Toro Z Master model #74170 PTO would not engage, next morning the battery was dead. Battery is brand...
(More)
Toro Z Master model #74170 PTO would not engage, next morning the battery was dead. Battery is brand new, 1 week old.
