Question about GE Microwave Ovens
JVM1450BA001 GE Microwave runs but does not heat. What is the parts # of the magnetron tube for that model?
  • 6,784 Answers
Ok, the part number is below but, i would advise to check the Magnetron thermal cut-off(Magnetron thermal fuse). This fuse could have blown.
MAGNETRON ASSY General Electric Part Number: WB27X10017
Posted on Jun 21, 2009
My GE model JVM1631WB002 is giving off a burning smell. What can I do?
A burning smell is usually a sign of a bad magnetron tube, the microwave source. As they age they take more power, and this causes excess heating that can cause the smell. Eventually the tube burns out and you get no heating. If you've been noticing longer than normal cooking times, it's due to the weak tube.
You can replace a magnetron, but it's a costly part (around $100-$125) and the repair should be done by a professional because of safety concerns. (Several websites describe how to replace a magnetron if you'd like to try it yourself, but you need to be very careful. MICROWAVES USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU.) Between the part and labor costs, when the magnetron goes bad it's often more economical to spend a little more and replace the oven.
There are some other parts that can get hot and sometimes smell, but the magnetron is most common. If you want to keep the oven, I'd suggest letting a professional check it over and give you an estimated for the repair. Then you can decide what you want to do.
Jun 06, 2011 | GE JVM1631 Microwave Oven
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Runs normal but no longer heats anything. model # JVM1451BA 001 serial # RT9227675
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
Sep 10, 2009 | GE JVM1630 Microwave Oven
I ran the microwave with nothing in the oven (obviously by mistake). Now it won't heat the food. Timer, clock, etc works. Is there a simple part that I can replace to solve this problem or have I killed...
You can replace the magnetron tube and , the heating will be restored. this is repairable.
Most magnetron tubes will run in the 120 to 140 dollar range.
Jun 19, 2009 | GE JES1142SJ Microwave Oven
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
Does not heat up
Bad magnetron tube. Call GE Factory Service 1-800-432-2737 or schedule online www.geappliances.com there is a 5 or 10 year parts warranty on the magnetron tube.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Please Help my GE Microwave produces no heat!!
Most of the time it seems to be the magnetron. The Magnetron is what heats the food, when you remove the magnetron sometimes you will see signs of wear like a black or brown spot on the tube sometimes there is even a hole burned through. A cheap place to find these part is Global Micro Parts in Dallas TX. Usually Magnetrons are about $30 - $45 and shipping is only 7.95 there web site is www.allapplianceparts.com
Oct 26, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave runs but does not blow heat
(((The fuse is located inside the unit along side the magnetron)))....
Oct 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
509 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
